P0446
Old 07-21-11, 03:24 AM
Angelgs300
Angelgs300's Avatar
Default P0446
Does anyone know where the purge canister is located on a 98 lexus gs300
Old 07-21-11, 07:38 AM
ThomasGS4
ThomasGS4's Avatar
I believe it's behind the rear driver wheel.
Before you go and replace things, check to make sure that you don't have any hoses loose. It's a common problem to have a hose leak in the 400/430. Not sure about the 300.
Old 07-21-11, 10:32 AM
Supraman18
Supraman18's Avatar
Can be a gas cap also...
Old 07-21-11, 11:23 AM
ThomasGS4
ThomasGS4's Avatar
It's recommended that you don't try to "top off" the tank after the pump has clicked off.
Old 07-21-11, 11:56 AM
tiger4life
tiger4life's Avatar
it's in the worse possible place. it's directly above the rear differential in a space between the differential and the body. service manual says to remove a driveshaft to get to it. unless you need it replaced for emmissions testing i would wait it out. i've gotten that code twice in thelast year or so. everytime i start to get concerned about it, it goes away.
Old 07-21-11, 04:29 PM
4play4dr
4play4dr's Avatar
Mines Been on for a while..I needa get this fixed too cuz I'm due for smog this year :/
Old 07-21-11, 05:26 PM
TonyN
TonyN's Avatar
I am gointo try to replace the purge valve first, it has a green cap and locates on the driver side along the fire wall. On that note does anyone have the part number or diy?
robo
11-12-23 01:18 PM
LexBrett
07-18-21 08:37 PM
TooJay
09-18-18 02:04 PM
thomasmcc
03-23-15 08:27 AM
Chefao
Performance & Maintenance
11-11-13 07:41 AM
Quick Reply: P0446
