Need help from Air ride experts
I bought my 2002 GS300 3 months ago, and it came with a UAS kit. I spoke to the old owner and he told me that the UAS kit on the GS was installed back in early 2008... I've been searching on CL forum, and read that there was a problem on UAS kit with the early users before 2009. The problem was, the front spindles will rub against the bags causing it to rip faster.
Well, here's my problem. I know for a fact that none of the bags are ripped, or it will be dumped on the ground because the bags can't hold air in it. My problem is actually the opposite of that, I don't use the bags often since I bought the car. Just here and there to show some friends. I usually leave it on DD height, about a finger and a half gap all the way around. But in the last week, after I park my car for a few hours and when I go in the garage to use the car again, I noticed that the front driver side is lifted higher than the other 3 sides. Not all the way up, but about 3/4 to an inch higher. It looks like the bag is filling air on its own.
Anyone of you ever had the same problem? Any advise on what's going on?
Thanks in advance!
Thanks in advance!
First try to fix, its not hard and no reason to spend money. Remove the pump valve for that bag, get some spray grease and a spare battery. Have someone spray in there while you tap the wires on a battery repeatedly (to open and close it) get it all lubed up and that should take care of the problem.
do you have a water trap on the compressors? The condensation could have gone through the tubes and dried up turning into guck in the valve area causing it to get stuck (you'll know once you pull it off) if it looks dirty from condensation, still clean it off then lube as said above, however I'd recommend to do the same for all 4 bags because if one is nasty, they all are gonna be nasty. I'd disassemble the valves and give them a thorough cleaning, they've been on the car for over 3 years and probably need a good maintenance/lube job (like most us men do )
Yea I have a water trap connected to my compressors. I just recently released all the water inside the trap. The water that came out was nasty, It was orange kinda like thai iced tea.
most likely the rust is from your tank (i bet youre running a steel tank??)
ide personally do a makeover with your air suspension setup.
Aluminum tank or at least a treated steel tank. (stainless steel would be behind AL)
clean the valves and get water traps... it doesnt remove all of the water but it takes out a good amount.
How often should I empty out the water out of the traps?
whenever you feel like it should be emptied...
CA isnt a super humid place so you wont be capturing LOADS of water. just drain it every month.. thats what i do and i only collect a small bit.
dont forget to empty the tank too since water traps dont collect 100% of the water being pumped in.. UNLESS you are running a long compressor to tank line.. longer line = more room for the hot compressed air to cool down.. this way its easier to collect the condensation.
