Help with aristo swap (parts) 2jzgte
i am having a hard time finding the right parts for the motor. supra parts are close but not the same (intake gasket) and others i need to get the tbelt and such. any ideas
I have found some to be the same but other not. The water pump for the gs come with the wrong back housing and the supra bolts up but alt bolt size is diffrent sizes. I am also thinking the vvti is some of the problem.
Do you mean the GE vs GTE not Supra vs GTE (unless you mean NA Supra). So you've tried your GS/GE water pump on the GTE/Aristo motor? Yeah I've test fitted that, and the front half bolts to the block fine, but the back half of the GE/GS is 1/2" shorter so the heater tube doesn't line up perfect, and the lower t-stat neck on the GE/GS has smaller bolt holes and is a different length and angle.
I'm using the GS/GE heater tube and t-stat neck on GTE block and GTE waterpump. They fit ok with a little modding.
The Supra water pump and VVTI Aristo water pump are the same, unless you are talking about the Hydro Fan Water pump, ditch that for a GS/Aristo swap and use your electrical fans..
Why would you direct him to go this route ? An guessing games by going to a Toyota parts department ????? Why do that an pay for shipping from Japan and have to wait for it ... Bro jump in a car head to the dealer (parts department ) an get what you need
