Humming Noise After Replacing Caster Arms
Old 07-28-11, 05:43 AM
rstreidl
rstreidl's Avatar
Default Humming Noise After Replacing Caster Arms
I replaced the caster arms (lower control arm #2) on my GS4, took it for a test drive and its making a resonating humming noise on the right side when I get up to about 35 mph, but if I hit the brakes it stops....any ideas guys?? I can't see anything out of whack with the brakes. I did have to do some jostling to get the bolts into the LCA. Any suggestions would be appreciated!
Old 07-28-11, 07:59 AM
99 GS3
99 GS3's Avatar
U sure it's not humming/roaring from the tires, you really should get an alignment after replacing the caster arms. Especially if they bushings were pretty far gone, your alignment could be drastically affected.
Old 07-28-11, 08:03 AM
rstreidl
rstreidl's Avatar
I'm pretty sure it's a mechanical metallic noise, not a tire noise. I'm probably going to take it to a shop to get it checked and get an alignment.
Old 07-28-11, 08:48 AM
exodus_2
exodus_2's Avatar
most of the time humming/roaring noise is comming from your tire or bearing. if you did not have that problem before and you just replaced caster arms????? so you might had your alignment off before and while you drove the car that way it will make your tire to wear out all weird and cause that noise when everything is strightened...
before you check your alignment swap the wheel left and right and see if that noise moves to other side then it's for sure that noise is comming from the tire.
if not might wanna check the alignment and your bearing as well.
Old 07-30-11, 08:49 PM
rstreidl
rstreidl's Avatar
OK I finally had time to give this another look...turns out the thin metallic shield that fits around the wheel assembly had gotten bent and was rubbing on the rotor. Bent it back, problem solved!
Old 08-01-11, 01:57 PM
sakataj
sakataj's Avatar
that would be the brake dust shield.......
Old 08-01-11, 02:22 PM
GS4_Fiend
GS4_Fiend's Avatar
that should make a grind noise not humming.
Old 08-01-11, 02:56 PM
sakataj
sakataj's Avatar
Yeah your right john, i didnt even think about that
Old 08-01-11, 06:39 PM
rstreidl
rstreidl's Avatar
Well it was a hummming/singing sound, hard to describe....glad it's fixed though. I'm sooooo thrilled though that replacing the caster arms has gotten rid of my CLUNKS!! The bushings were badly cracked on both sides. Thanks to the good info on here, PROBLEM SOLVED!~
chicov8
04-29-15 02:38 PM
Natey2
02-15-15 06:59 AM
chunkyda
12-03-13 06:49 AM
Enigmatic
12-20-10 06:13 PM
mikemareen
09-18-08 05:59 PM
Quick Reply: Humming Noise After Replacing Caster Arms
