vsc abs craziness help please
ok i have a 98 gs300. i had the dreaded vsc vscoff abs lights come on. so i start the trouble shooting. first i get the codes read. easy right. wrong.... i iget the code for the wheel sinsors. so i go into fixing the problem. great. not so much. I have fix the wheel sensors. turn on the car. lights go off for a day. then come back on. so I then check them again and they r fine. same code. they test out great. 1.7 ohms. put them back in. start the car. no codes. awesome... next day same lights same code. checked the bearings they wear alittle worn. so i put in the bearings and seals. problem fixed. until i start the car and drive off. lights come on then car goes into limp mode. crazy.. i pull the codes and get the throttle codes a tps code some random misfire codes and the bank 1 code. I have changes the ocv and all the other little stuff. now i have to find this problem. i seems like everything has gone bad at one time. does anybody have any ideas what else to look into. or a good wiring diagram for whatever controls the vsc abs system. the sciatics would be awesome if anybody has those. or am i just missing some component. ive had it with this car. help me please.........thanx
Don't have a wiring diagram, but there are like 60 wires going to it.
Here is a pic of the abs/vsc/trc controller, it is under the steering column by your left knee.
Toyota Part number: 89540-30390
Is there a way to test these sensors? I've found the tps sensor test. and the wheel sensor test. Is there a way to test the throttle control motor or the computer. I've also been told it could be the yaw rate sensor. If any body has some type of test for all the sensors that would be great. Are there any other sensors in this systum that i might be missing..
thanks for the help...
OK i reset the computer. the lights are now off. I start to drive the car the skid light comes on and the vsc starts working then goes into limp mode. No lights come on just the one that shows the car sliding. I can turn off the vsc with the vsc off button and car works like normal. On a side note the brakes seem to be acting up with this stuff going on. the brakes will work just fine until about half way down. Then they seem to let go for a second then the abs will kick in and the pedal jumps back and forth for a second. when this is happening there is no brakeing going on. Then the brakes kick in like they never had a problem.
some how i think this is all related. but how and where do u start. I can drive far enough to get new codes because of the brakes. if i drive with the vsc on i cant go anyplace because of the limp mode. this is driving me crazy. please help.....
Def cant tell you all the sensors but I would focus on abs because if abs isnt woeking right neither will vsc but without vsc abs should work fine.... If your having brake issues as well as vsc issues I would switch form vsc sensors to abs sensors..... Just a thought
ugghhh i got this same issue going on... mine started last friday after going through a car wash... i turned the vsc off and it was fine driving but when it was on i had weird sounds coming from the brakes and the car felt a lil rough accelerating from a complete stop. I kept the vsc off and when i got off work all was fine. Today after a day of rain ... leaving work all three lights lit up from vsc over to the right. I pushed the vsc button since this worked last time... but this time they all stayed on. The only thing different that I did last Friday was get a brand new Die Hard just before my car wash. I doubt that has anything to do with it... but from reading a few threads i'm thinking ABS Sensor or Alternator... maybe the speedsensor... but more so the ABS since i have the weird noise from complete stops to acceleration. We shall see...
