2000 GS300 MAF air flow check
Old 07-31-11, 08:13 AM
2jzgttegs
2jzgttegs's Avatar
Default 2000 GS300 MAF air flow check
Does anyone knows what's the resistance on a stock GS300 MAF air flow?
Old 07-31-11, 09:40 AM
tiger4life
tiger4life's Avatar
learn to use this manual
http://bahamutcars.free.fr/workshop/...nts/index.html
Old 07-31-11, 10:09 AM
ThomasGS4
ThomasGS4's Avatar
That manual doesn't work on everyone's computer...
Old 07-31-11, 10:38 AM
PHML
Master Thread Closer!!
PHML's Avatar
thats the 2001 MAF sensor
Old 07-31-11, 12:37 PM
GS4_Fiend
GS4_Fiend's Avatar
According to ALLDATA, it's the same procedure and specs for a 2000 GS300. Also true for 01-05 GS430/300.
Old 07-31-11, 01:13 PM
tiger4life
tiger4life's Avatar
Just pointing out to him that it existed
Sorry, here is the 98-00, I thought I read 01
Old 07-31-11, 01:22 PM
tiger4life
tiger4life's Avatar
If your maf fails the resistance test, I would replace it with a brand new oem maf. My engine started vibrating. You could feel it through the steering wheel. I changed the timing belt, valve cover gaskets, motor mounts, transmission mounts, and exhuast mounts. There was still a faint vibration. Changed spark plugs, wires, and pcv. Still there. It was driving me crazy and I thought it might have been the injectors. Turned out it was the remanufactured maf I bought from Autozone. I was chasing the small miss for a year and it was the damn Autozone maf! Checked the resistance and it was out of spec. Of course I figured this out 1 month after the warranty ended. Bought a new oem maf and car no longer vibrates.
Old 07-31-11, 08:26 PM
tinman
tinman's Avatar
It seems to be related to the browser they are using. It doesn't work in Firefox or Safari. It works in IE8 and 9.
Old 08-02-11, 09:48 AM
2jzgttegs
2jzgttegs's Avatar
I check it and it was good! Thanks for the info
Old 08-02-11, 12:42 PM
sakataj
sakataj's Avatar
that is correct it WILL NOT work with FF it works fine with IE....one of the ONLY reasons i still have IE on my laptop is to use it on that.
Old 07-04-13, 06:28 PM
jcjcrespo
2nd gear
jcjcrespo's Avatar
Default Try Chrome
I'm using Google Chrome and can view the manual perfectly. Cheers!
xJimy23x
01-08-17 05:08 PM
martin2301
03-23-14 02:13 PM
lyles3
02-23-12 10:08 AM
NIXmx
Performance
02-20-10 11:23 AM
Dx3
04-28-06 03:54 PM
Quick Reply: 2000 GS300 MAF air flow check
