Tires only lasting 2k miles. Please Help.
This issue is only occurring with my front tires. I am running Achilles 225/35/19 on a 19x9.5 +22 offset. The tires are pretty stretched. I got about 2k miles from one side and now I need to flip my tires. I did not get a alignment after I replaced to this new setup.
My previous setup was General 225/35/19 on a 19x8.5 +24 and I was able to get about 5k from one side and another 3k from the other side. I did do an alignment after I got this setup.
I have already replaced all the bushings from a Daizen kit before I got my new setup.
The height did not change when I got the new setup.
My questions are:
1. Should I get an alignment after I replace my tires?
2. The place that installed my wheels over torque my lugs. Does this affect tire wear?
3. Is this normal tire wear?
4. What is your experience with stretched tires with this much negative camber?
5. I am planning on running a 235/35/19 tire to replace these ones. Should I do an alignment now or wait for the new tires?
Thanks for all your help!
My questions are:
I just got my tires flipped. This was originally on the driver's side front. They looked more worn in person.
Thanks again!
http://www.flickr.com/photos/21897713@N08/5999152494/
http://www.flickr.com/photos/21897713@N08/5999165218/
http://www.flickr.com/photos/21897713@N08/5998622973/
Passenger Side
http://www.flickr.com/photos/21897713@N08/5999174754/
Thanks again!
Passenger Side
what PSI are you running in comparison to what's listed on the tire?
I think you're trying to show outside tread wear?
the more information you provide the better feedback you'll receive.
i'd say alignment, i've been there with my GS's and SC's..
I hate paying for them but they are alot cheaper then tires, Lex's are horrible about eating tires if you have a modded suspension and improper alignment..
jeeper2269
11-10-16 10:33 AM
