Air suspension guru! I need your help ASAP pls
My front won't air up or do Anything, but the rear work just fine..
This is what I did.. I just reteflon the front valves I took it apart all fittings and reteflon them and put them back together..
Checked all the wires and they seem to be fine..
Tried to air up the front and it won't do anything, tried the rear and it work just fine..
Help guys..pls
Help guys..pls
I swiTch the valve from front and rear thinking it was the valve..
Took the valve from the rear and rewired them,
Front still won't air up or do anything,
Rear work just fine..
Maybe the front ground?
when you hit the switches do you hear the valves clicking at least? or nothing at all.
re-tefloning the valves and fittings wont help a non working valve btw lol only leaks. hehe
you can check to see if youre getting power to the front valves with a multimeter. If there is no power when you hit the switch then you can limit your search to the switch box or something
Yeah I think I can hear the valves..
No the reason why I reteflon the fitings is cause Im having a air leak.. I took a soapy water and sprayed and saw some leaks so I took it apart and reteflon eveytthing put them back together and now I'm having problem
He reason why I switch the valves is to see if I have a bad valve..
Ok no wiring problem..all the valves are working..
Checked the hose and there's no air comin out so it's not supplying air to the front...I bought a regular air hose from home depot and now front air up but ders a huge leak on the valve..
Because I use a regular air hose?
