Seriously?
08-10-11, 09:57 AM
Seriously?
Do these get damage easy? Both of my hose not don't flow air..
08-10-11, 11:03 AM
check the check valves. Its off the compressor right? Cant tell cause my screen sucks
08-10-11, 11:18 AM
looks like a Viair air hose from the compressor...
the bottom has a check valve that only allows air going on way... so you cant easily get air pushing it with your mouth.
unless you know how to blow hard.. (drums) jk.
08-10-11, 11:20 AM
my question is.. what the heck are you doing to your air setup?? either youre having many many problems or you originally had 1 problem but in the course of finding out the solution more crap hit the fan.
08-10-11, 11:51 AM
Kit came with 4 of hoses like this.. 2 from the compressor to the tank and 2 from the tank to the electric valve
08-10-11, 11:56 AM
08-10-11, 12:48 PM
gotcha. i see your setup.
Hose > Check valve > Air up > air down
08-10-11, 12:52 PM
Can I use a regular hose for that?
From tank to the electric valve?
08-10-11, 01:00 PM
Tank > Fitting > Hose > Fitting > valve.
Basic run down.
use DOT rated air lines..
ihatecarz
Performance & Maintenance
03-03-19 08:37 AM
ihatecarz
03-02-19 03:54 AM
c-low
VIP Style
20
09-18-13 02:56 PM
phamxOC
02-07-11 11:38 PM
Fern
RX - 1st Gen (1999-2003)
04-14-04 12:14 PM
