Did I get a bad tank of gas, or is my fuel pump going out?
Old 01-03-13, 01:29 PM
lextout
lextout's Avatar
you can rule out the fuel pump, its either good or bad, and if its bad you aren't going no where.
Old 01-03-13, 08:43 PM
GS4_Fiend
GS4_Fiend's Avatar
Originally Posted by jjbenzo
Last weekend I ended up spending some time to clean out the throttle body. I used the same CNC throttle body/air intake cleaner that most use. Everything cleaned up quite nicely. I did order a new mass air flow meter and throttle position sensor from Lexus as well. I installed the mass air flow meter last night (I was amazed at all the build up on the old one) and I have an appointment at my dealer to get the throttle position sensor installed (along with fuel injection cleaning) tomorrow. I'm bringing it in because I stripped one of the two screws that hold it in place on the throttle body. So far with just the throttle body cleaning and new MAF meter, the car seems to be running great. My cars only get full synthetic oil and premium fuel, so it is rare that I run into any major issus. Below are a few pictures of the throttle body and the dirty sensor portion of the MAF meter.
Did you clean with a brush?
Old 01-04-13, 11:55 AM
jjbenzo
jjbenzo's Avatar
No, I did not clean anything with a brush. I used throttle body cleaner and a clean rag to take care of the throttle body and air intake box, and I simply bought a new MAF sensor/meter to replace the old one.
On a side note, my GS is at the dealer right now to get the new throttle position sensor installed (I stripped one of the screws that hold it in place). When I dropped off the car, they told me that it is common to have to replace the actual throttle body, not the sensor. Never heard this before.
fmm009
Maintenance
04-04-16 08:31 AM
2008GSh
Hybrid Technology
12-23-14 08:03 AM
konradsa
RX - 3rd Gen (2010-2015)
09-24-13 06:46 AM
FireCode
Performance & Maintenance
07-11-05 04:37 PM
Quick Reply: Did I get a bad tank of gas, or is my fuel pump going out?
