Oil change on '03 GS430
The import shop I use in Raleigh has finally priced me out of using them for oil changes on my '03 GS430. They have maintained my other car (Acura CL-S) for several years, and my Lexus for the last year. They are now at $65 + shop fees, etc for an oil change.
Two questions: How difficult is it to change the oil on the 430? My wife's Suburban is easy -- you can reach everything by just laying on your back. Are there any gotchas to be aware of? The Acura has an aluminum oil pan that you have to be really careful not to overtorque when reinstalling the drain plug.
The second question is does anyone trust their oil changes to a non-dealer/non-specialty shop? There is a local chain (Colony Tire) here that has a good reputation, better than that of a place like Jiffy Lube, who I would simply not trust due to horror stories from friends.
Thanks for the link, GSteg!
Maybe I should just stop being lazy and do it myself. I've got the ramps and the wrenches, and removing the undercover looks easy enough.
Is it worth the money to get the Toyota filter? Or can I get by with Purolator filters?
Wow.....$2 - 2.50 for Toyota filters? That's cheaper than I thought they would be. I'm happy when I can get the PureOne's from Purolater for under $7!
Does the Lexus have a crush washer (I think that's what Acura calls it) that should be replaced on the drain plug like my CL-S does?
Normally I use Mobil 1 or K&N filters on my toys (Turbo Supra, Turbo SC)
on my GS's, Accords, Camry's i've always just used puralator, oem or just a descent good filter..
