Fog Lights w High Beams??
girvan:
what about to keep fog lights on with just DRL ? in my 98, I dont really have 'em but if i just turn it once those middle bulbs lights on.. do you know how to make fog lights to start operating as soon as this switch switch to that position and higher (lowbeam,auto)
Originally posted by GS430lvr
Well so far I've found the following:
"Hey, how do I do this??? VinnyIS300 has his fogs hooked up solo to the OEM switch... He pulled out the relay, bent one of the prongs so it doesn't plug in and then tied a wire around the then put it into his ignition fuse... And it works... I tried to do it with him and on my GS I had no luck.... I can do it by putting in another switch in but I want to use the switch by the steering wheel.... "
Anyone try this on the GS? I'm not going to add an additional switch so I can bypass the cut-off (I want to use the OEM switch)....there should be a way to trick the relay??
It justs adds a bit more light w the high beams and it does look cool...& I always flick the h-beams off for on-coming vehicles.
MAK1885942
ES - 5th Gen (2007-2012)
10-21-16 11:10 AM
Chris442
12-31-15 05:00 PM
PlumBob80
01-28-15 08:08 PM
