Check Engine, VSC, VSC OFF, Lights are on
seriously please stop....their are MANY reasons he could have the EXACT same lights. WAIT till he pulls his code....and while he could have the same p1349 that DOESNT mean that this will be the ONLY code he will have so it still wouldn't necessarily mean he has the same issue or problem your having.
please dont assume to know the codes before the OP even posts them, your not physic brother, just give him time to pull them
Okay, so I got them checked out. Its an oxygen sensor. P0037.. The Lexus dealership wanted $400 to replace it. Needless to say I passed, so now if anyone has any idea on how to replace this. I am all ears!
well,that would explain the CEL code but not the VSC/VSC OFF light...
i ask again,before the lights came on did you get into a wreck or have any suspension work done where you might have ripped the speed sensor? any issues with the master cylinder or has it been replaced?
thats the ONLY code u got?
Yep. Thats the only code I got. No wreck, no suspension work, no issues with the master cylinder.
iModerate
The ABS/VSC system stores codes separately from the normal OBDII (engine) codes. If the store/shop you had scan the vehicle for you only scanned the engine/OBDII system all they will get are engine codes. The ABS/VSC needs to be checked with a capable scan tool, usually a high end scan tool or factory tool.
You may still have ABS/VSC codes you are not aware of.
tengo el check engine, el vsc y el vsc off encendidos, lo lleve al mecanico y me dio que los codigos son el p0300, p0302 y el p0305, le chequearon la compresion de los cilindros y estaban bien, le cambie los coils 2 y 5 para ver si tenian problemas, el carro no tiene escapes en el muffler, les cambie las bujias y he hecho de todo y las luces nada de apagarse, el carro no tiene ningun fallo, lo ultimo que le estan haciendo es chequeandole la computadora, por favor quien me puede ayudar con eso.....
akafixture
02-13-20 05:28 PM
LXBriGuy
05-19-16 03:11 PM
