GS300 overfill oil to 6 quarts
Hi,
My mechanic went on vacation so i was passing by my old mechanic. Stopped by his shop... one of his guys... filled 6 quarts into my GS300.
I asked him... "Did you use all 6 quarts?"
Grease Monkey - Yes, it takes 6.
Me - No, it does not take all 6 quarts.
Grease Monkey. It takes 6.
I let the engine run. Waited like 30 seconds to measure the dip stick. It looks just very slightly... can't really tell it is much over mark.
But inside of me, i've always been using at about 5.75 because spec is 5.7.
Question - should i be worried that it is 0.3 quarts over?
The point is that it only needs to take .3 quarts. Since the tech poured the remaining .3 quarts of my mobile 1 synthetic into the engine, i basically wasted $2.00 because each bottle cost me $7.00.
I will never bring it to that shop again.![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
Thanks all. I will ride on this until my next oil change.
If in doubt, only hand them 5 quarts and top off your self later.
According to the manual, this engine is made to burn a little oil between changes (though it never says how much) the extra would just be insurance. The difference in volume between the two will NOT be enough to cause interference or have the lobes of the crank splash into the oil and cause any windage losses or anything of that type. You're perfectly fine...
If in doubt, only hand them 5 quarts and top off your self later.![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
