Yeah, it's the same color. This wrap is called ME-379 brushed aluminum. It's the same color but has a brushed aluminum feel. It looks subtle but classy IMO.
Doesn't look stock to me. It's very subtle, and I really like how that turned out Yvie.
SoCal, didn't know you wanted to do a vinyl wrap when you first posted. CarbonGS did real carbon fiber, that's why he could clear coat it.
i actually just talked to him. getting prices for real carbon.
OP. Have you seen & touched 3M DI-NOC ? There is no need to clear coat it. It is not your typical vinyl as it has the texture & feel of genuine c/f. I have 2 genuine c/f plate frames for sale if anyone is interested.
also i was going to have my body shop guy use exterior automotive grade clear coat, not just from a spray can from home depot, if this clairifies anything?
that looks great! wow, i might have to change mine up.
Thanks!
Originally Posted by SoCal Cyco
now doesnt the 3rd on look the best to anyone else?
Actually the non-clearcoat vinyl in this pic looks worse than in real-life IMO. It's very difficult to clearcoat larger surfaces of Di-Noc. From what I've seen it isn't easy to get an even result over the whole surface.
If you get it installed on your door trim, the door panels will have to be removed in order to remove the "wood trim" on the doors. The trim is held by 4 bolts so don't pull or tug it off. After closer inspection of the trim on my doors, it appears to be abs plastic that looks to be painted in a wood pattern You will see for yourself..
