I think I figure it out. The intake was there. The engine bay got wash clean and maybe some water got in? It limps once it starts driving and no check engine. If so, how could I clean the water?
Get some compressed air and blow around coils, also remove spark plugs and do the same inside cylinders, should be fine afterwards. I wouldn't drive it with the misfire you might damage the cats.
Ah drove it like that so far ok... I hope it doesn't take a ctrap on me since I did 450 miles ha. I keep getting the stupid vsc. Vsc off check engine light cuz of the gas cap arg
Check for water4 and nothing.. scanner said 5 coils are bad and replaced them..
After that.. car still missfire.. Still shakes.. still hesitate whenever i accelerate??
took the maf out cleaning it right now.
Do u know the voltage reading of the maf?
Mine is going from 7 to like 9. something
Disconnecting the battery right now and ill check wa zup
According to manufacturer testing prodecures:
Disconnect MAF sensor and test the resistance within specs:
Terminals THA & E2, the first and second pin.
2.21 - 2.69 k ohms @ 68 degrees F
.49 - .67 k ohms @ 140 degrees F
Also, try disconnecting the MAF, then start the car and see how the car runs, if it runs better than MAF is bad as I already stated.
