Vsc, abs, vsc off lights on
Old 10-12-11, 11:53 AM
airahcaz
airahcaz's Avatar
Originally Posted by sakataj
while you DID fix the broken LBJ you did NOT fix the speed sensor that got ripped when the LBJ broke. you can either repair the sensor yourself with a OHM meter, some solder, and some patience or buy a new one and replace it....but those lights will not go away till THAT issue is addressed.
BTW if u do replace it i wouldnt mind buying the old one for a spare or we
I can get mechanic to solder it but it was indeed attached just like the right hand side, where else to look?
what do they run? I'll surely give it to you for cheap if I can figure out how to get a new one replaced if needed
Old 10-12-11, 12:33 PM
sakataj
sakataj's Avatar
i dont mean this in a bad way but are you mechanically inclined at all? some people are not so im trying to grasp if you even capable of doing the repair.
yes it PHYSICALLY is attached but inside the wiring its ripped someplace. the rubber coating has to be opened, if you OHM it out you will find there is indeed a break in the wire and then you would just need to trace it back to find out where it ripped and then solder/reattach it.
jefftsai used to have a DIY with pics but all the pics are gone and he hasnt ever updated the pics...
i know for awhile he was fixing them for people but i dunno if he does anymore or not.
new i think they $160-200
Old 10-12-11, 12:56 PM
airahcaz
airahcaz's Avatar
if not broken and can do a trace, solder is not a problem - now to tell if it is actually broken is another story
Old 10-13-11, 03:08 PM
airahcaz
airahcaz's Avatar
Hey - does that mean the actual VSC and ABS is disabled even though it may just be the sensor?
Old 10-14-11, 08:11 AM
airahcaz
airahcaz's Avatar
So Firestone checked, and the wiring and sensor are fine - now what?
Old 10-14-11, 09:09 AM
GS4_Fiend
GS4_Fiend's Avatar
Clear codes then drive it. Abs light come on again retrieve the code amd get it resolved
Old 10-14-11, 11:46 AM
airahcaz
airahcaz's Avatar
Can autozone clear em or can I do myself?
Old 10-21-11, 09:26 AM
airahcaz
airahcaz's Avatar
So disconnecting the battery for 30 minutes did not work.
Jumping E1 to Tc also did not work, unless i didn't do it correctly. The red BRAKE warning light started blinking with a constant beep - I then jumped out the car, removed the jumper, shot the ignition, replaced the short pin, and started the car. All the amber lights are still on VSC and ABS
Old 10-21-11, 09:30 AM
alloys999
alloys999's Avatar
Try to Reset ECU just remove the battery for 1 min i hope this will help you even once i got my all dashboard lights on just removed battery now it is 4 months i dont have dashboard lights on. just try
Old 10-21-11, 09:36 AM
airahcaz
airahcaz's Avatar
that was the first thing I tried, as mentioned
Old 10-21-11, 09:52 AM
cdg306
cdg306's Avatar
c1223 is general ABS control malfunctiion code.
c1233 is yaw rate sensor.
c0205 is for the left front speed sensor.
Id start with the speed sensor.
Measure resistance between each of terminals 1 and 2 of speed sensor connector.
Resistance: 1.4 − 1.8 kΩ
Next measure resistance between terminal 1 or 2 of speed sensor connector and body ground.
Resistance: 1 MΩ or higher
If those are ok then it's probably in the wiring.
Old 10-22-11, 09:50 AM
airahcaz
airahcaz's Avatar
have pulled it apart, no resistance is showing between the 2 terminals at all, stays at 0
Old 10-22-11, 10:43 AM
airahcaz
airahcaz's Avatar
Checked right side, saw the resistance.
Bought new one, checked resistance, about to install.
Lexus doesn't sell just the sensor, had to buy with the wiring
fingers crossed
Old 10-22-11, 04:15 PM
lexluger71
lexluger71's Avatar
just had my ball joint done and the vsc and abs lights are on, car drives fine, do i need to replace anything, i reset the ecu and lights still on, how long can i drive before serious damade?
Old 10-22-11, 05:40 PM
airahcaz
airahcaz's Avatar
You need to check your speed sensor. That was my problem. Fixed now.
You won't have serious damage, but it is dangerous to not have abs or Vsc.
Quick Reply: Vsc, abs, vsc off lights on
