Vsc, abs, vsc off lights on
Old 03-28-16, 12:18 PM
  #46
sbagdon
sbagdon's Avatar
Originally Posted by Acidic
I have been dealing with this same issue. I searched and there are SO many threads it's hard to find the right steps. I downloaded the PDF from one of the threads so I'll just attach it here. One more thread with the PDF in it will make it easier to find. The procedure to read the codes is section 2. Sensor signal check.
The reset procedure is one of the first section that talks about not having the handheld tool
Worthy of a shout-out/bump. Printed out the pdf, will check for codes later today, bought car with the lights on, told left/front sensor, time to finally confirm, get some new parts in there, and get those lights off.
Old 09-10-18, 10:33 AM
  #47
PublicSnar
PublicSnar's Avatar
Originally Posted by starfyrels
Either you need new abs sensors on each wheel or your tires/wheels are bad or you just need to reset the abs/vsc -- do it under the hood. if you can find the steps then kudos if not just pm me and I can look and see where i have it. You use the diag port under the hood to clear it.
What do bad tires have to do with it?
Old 09-11-18, 12:55 PM
  #48
sbagdon
sbagdon's Avatar
Presumably, the system depends on all 4 wheels rotating in a predictable way, to what the system is expecting. So if one of the wheels/tires is out-of-round, or has too small or large of a rotating distance, the system might believe that one of the sensors is always bad, and disables the system (until the out-of-sync item is fixed).
Old 09-12-18, 04:35 AM
  #49
Kretek234
Kretek234's Avatar
Originally Posted by frankiejay
Hello team !! I have 1998 lexus gs400 and i installed some megan racing coilovers 2 weeks ago yesterday i picked up a set of satggered wheels 20x8.5 and 20x10 when u ajusted my coilover to the way i wanted it the vsc, abs, vsc off light came on .... Doesn any one now why this happens ? If u could please help me out thanks guys have a good day
It happened with my 99 gs 300 4 month ago. The battery depleted, finally I check the alternator.
I replaced the Altenator, and all the lights never come back on.
I hope this help.
shmuliebz
11-08-17 06:15 PM
Jayd41
05-21-14 09:26 PM
smokincigs
04-10-11 12:47 PM
panamabob
11-07-10 05:31 PM
systemover
10-31-08 02:22 PM
Quick Reply: Vsc, abs, vsc off lights on
