Vsc, abs, vsc off lights on
Hello team !! I have 1998 lexus gs400 and i installed some megan racing coilovers 2 weeks ago yesterday i picked up a set of satggered wheels 20x8.5 and 20x10 when u ajusted my coilover to the way i wanted it the vsc, abs, vsc off light came on .... Doesn any one now why this happens ? If u could please help me out thanks guys have a good day
the shop i went to removed the tps sensor to check if the break was in the lines so they identified the problem there. i was getting my suspension put in and one of them prob. hit the wire and split it internally. just bring the car in to a trustworthy shop and have the sensor tested first before moving on to just replacing items.
I recommend checking the ABS/speed sensors. When they installed your suspension, they might have pulled the wires too hard and damaged the wires running to the ABS sensors. Most likely you will be able to solder it back.
One of the wires on my front sensor broke right at the head when my ball joint popped out, but I was able to solder it and it worked fine.
Hambone63 (07-10-24)
hey guys i took the car to one of my friends mekanik and he plugged in the scanner and it gave these codes C0205, C1233, C1223 and it said LF WHEEL SENSOR FAULT, EITHER TO CLOSE OR TO OPEN, ABS FAULT ? i did replace the LF WHEEL LEVEL SENSOR BUT NOTHING HAPPEND
Account under Legal Action - Banned
Either you need new abs sensors on each wheel or your tires/wheels are bad or you just need to reset the abs/vsc -- do it under the hood. if you can find the steps then kudos if not just pm me and I can look and see where i have it. You use the diag port under the hood to clear it.
I have been dealing with this same issue. I searched and there are SO many threads it's hard to find the right steps. I downloaded the PDF from one of the threads so I'll just attach it here. One more thread with the PDF in it will make it easier to find. The procedure to read the codes is section 2. Sensor signal check.
The reset procedure is one of the first section that talks about not having the handheld tool
BTW if u do replace it i wouldnt mind buying the old one for a spare or we
