squared stance
09-18-11, 07:30 PM
Quote:
Originally Posted by
2gs4u8
is 19x10 front n 19x11.5 too aggressive for 2gs?how much fender do u have to pull?
depends greatly on the offset
09-21-11, 08:33 AM
I just sucked it up and bought a staggered setup, having the same size width and diameter would have been nice, tire wise
09-22-11, 11:34 AM
What did you go with size and offset?
09-22-11, 12:40 PM
Megans LP coilovers
LS calipers + Figs front RCA and Mega Arms
Concept One RS-22 20x10 offset +38
can this work?
09-22-11, 09:10 PM
Should fit fine...thats not a low offset. Normally with coilovers if your riding low can go with 25 offset
09-26-11, 06:35 AM
scriber
20x9 +25 20x10 +30.. I'm thinking of using a 5mm spacer in the rear to give the stance a slight push in the rear
09-26-11, 10:30 AM
Mangineer
Sounds good. You could even put a spacer on the front and more in the rear. For example a 20x9.5 +22 and 20x10.5 +22 No spacer would put you flush and tucked and look sick imo. So maybe on a 20x9 and a 20x10 +30 you could go in the range of a 15-20mm spacer for a flush but still tucked look
09-26-11, 12:48 PM
09-26-11, 06:50 PM
2gs4blue
im at 20x10.5 n 20x 11.5
What offset?
09-26-11, 06:57 PM
Ant2gs3
its called staggered
Ant2gs3
oops sorry i read it wrong thought he wanted 18x10 in front and 19x10 in rear
Your Kung-fu is Weak my Friend..
SkyPara82
RC F (2015-present)
18
03-15-18 02:32 PM
Jaybeck860
IS - 1st Gen (2001-2005)
01-19-14 08:31 PM
818GS
08-29-12 08:15 PM
J.P.
Wheels, Tires & Brakes Forum
07-17-02 04:05 PM
babyboy
09-26-01 04:24 AM
