FAQ: GM LSx Engine Swap into 91-2005 GS300/400/430 / 01-05 IS300 / 91-00 SC300/400
#51
I am going to fab my own, I have done mounts before for swaps.
On paper I have most of the wiring figured out..... The reason I was was wondering about the PS/AC/Heat was the PS has a Solenoid , and heat has the actuator outside the firewall..... Being the digital style climate control unit I wasn't sure how all that interacted with the new stuff
What did you go with for throttle body drive by wire?
#52
I've heard you can even build your own brand new ls7 or ls9 right at the GM plant. I have no clue what the extra costs are.
Would be interesting to know what advantages there are for the different LSX motors? Size, Power differences, durability, easy of installation, availability of parts ect...
#53
So I'm doing a 5.3 lsx in a sc300 already was MT stock. Found the 1350 adaptor so is the 1350 flange meaning a cv flange? Not to sound dumb just getting into fr cars and leaving Hondas lol
#54
Get the driftmotion adaptor. The adaptor goes from Toyota/lexus 3 bolt pattern to a 1350 style. Then go to your nearest driveline shop, take them a stock f-body driveshaft and tell them that you want to convert the u-joint and flange to a 1350. Thats it. Done. No lengthening, no shortening, no nothing. Bolt it up and go! Ask me how I know this lol
#55
Here is the adapter installed:
![](https://lh4.googleusercontent.com/-cdfynsARQHs/TgjKmpHd8-I/AAAAAAAAAiQ/7mn4Ip_J2BE/s640/IMAG1191.jpg)
#59
Mike, this is a really cool swap and I am surprised that not more people have done it. I also like that you went with the LS2 6.0 which is step above the LS1 but doesn't break the bank like the LS7. There are no shortage of guys that are making 400-425rwhp with exhaust, cam, under-drive pulleys, intake manifold, and tune. So the LS2 is a great choice and they sell for about $4500 with all accessories and T56 with reasonable mileage. I have a few questions and I apologize if you brushed over these points above already:
a.) What part of So-Cal are you located? Wish you were closer to me so I can pick you brain more, lol
b.) I like that you used an external clutch pedal. Is it sufficiently spaced from the brake pedal? Looks pretty close, but it may be the camera angle. If you were to do it again, would you use the Wilwood part or get the IS300 assembly? Is the is300 assembly a bolt-in?
c.) If you have a GS400/GS430, what would you think about using the stock radiator/fan assembly? I am guessing it would be fine for a street car that doesn't see any major endurance stress.
d.) I'm really curious as to what the process was to get it smog legal. Can you shed some light on this?
e.) Were you ever able to figure out the water gauge? Or do you constantly have the OBD-II port occuppied for the water temp read-out?
f.) Do you know how much variation there is between the T56 that comes in the LS1, LS2, LS3, etc etc...? I'm sure that the LS2 T56 from the GTO is plenty strong.
g.) I just read that the engine mounts and tranny mount combo costs in the ballpark of $1000, LOL! That's nuts! I guess it's due to low volume. I would think if the demand was higher, we would be getting these parts for $200-300 max.
h.) Tell us about the AC. I assume you are using the GTO compressor?
i.) Just curious, what year is your car and what did you pay for the engine/tranny? Mileage?
j.) What bolt-ons do you have to make that 373 HP? It looks like most 05-06 GTOs dno right around 350rwhp SAE with the M6
k.) In post44 you mentioned that you removed the STOCK MASTER CYLINDER ABS/VSC. How then do you still have ABS?
And lastly, you have to get us some videos man!
#60
There is plenty of room between the clutch and brake. Its in the pwerfect spot and seems very natural when driving. I would go with the combo i did all day long. loving it.
for a few hundred bucks, i would get the largest radiator and fan you can fit. These motors like to run hot. Why skimp on a stock rad/fan and risk over heating. even the stock GTO rad sucks. everyone complains.
make sure all your OBD2 is working with all the smog equip from the donor car. motor must be from a car (not a truck) and newer and more efficient than motor being removed.
not even worth it to me, the water temp gauge sucks anyway. I would MUCH rather have a number in degrees F than the gauge. Its precise. So I will stick to the scangauge
T56 is a T56. The only diff is the bell housings for ford/chevy/dodge
they are made to order. if you had them mass produced 50-100 sets it would probably be half the price. not something i want to invest in. Plus everything is manufactured here locally in the USA
GTO compressor, lexus condenser, all custom lines. Another member here helped me figure out the AC system, had issues triggering the compressor at first. Now it all works perfectly
this doesn't matter
exhaust, JBA shorty headers, K&N intake and HP Tuners
I don't have ABS, removed it ALL
And lastly, you have to get us some videos man!![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
no videos, sorry man
this doesn't matter
