FAQ: GM LSx Engine Swap into 91-2005 GS300/400/430 / 01-05 IS300 / 91-00 SC300/400
Old 12-15-12, 11:26 AM
  #61
doug118
doug118's Avatar
Has anyone ever mated the factory GS trans to a ls1?? I just picked up a complete 4.8 for $200 so I'm looking to see how hard it would be to mate it with the factory trans. I'm not trying to go fast. Just needed a replacement engine for my car so the stock trans will do just fine
Old 12-15-12, 06:53 PM
  #62
00Formula
00Formula's Avatar
It would probably be cheaper and easier pick up a GM 4l60E transmission than to try to mate an LS motor and Lexus trans. Lots of people sell their 4l60E in the LS community to upgrade to a 4l80E to handle more power, so you should be able to pick one up for $500-700.
Old 12-16-12, 07:46 PM
  #63
doug118
doug118's Avatar
I actually have access to a couple of th350 trans that I can probably have for $100 with coverter. I just prefer not to get into making a trans mount and driveshaft but it looks like that's what I'll have to do
Old 07-02-13, 04:17 PM
  #64
Nichles3
Nichles3's Avatar
Had anyone looked into using this Canton Racing front sump pan in a GS300 swap? P/N 15-276. Guess people are using them for 240sx swaps.
Looks like the sump is 6 3/4" long if I am understand it correctly and the info is correct off http://www.enjukuracing.com.
Old 07-08-13, 04:28 AM
  #65
AMSMIKE
AMSMIKE's Avatar
Yes Canton 15-276 will work just fine. Must use the GTO oil pick up.
Old 07-08-13, 05:59 AM
  #66
Nichles3
Nichles3's Avatar
This is great news. I just so happen to have a GTO dropout. I also like the idea of having the extra oil capacity.
Old 07-13-13, 05:44 AM
  #67
Nichles3
Nichles3's Avatar
Has anyone tried any off the shelf long tube headers that will fit with this swap?
Old 09-10-13, 12:52 AM
  #68
Dscustoms
Dscustoms's Avatar
No, headers are an absolute nightmare to fit, it's very snug in there.
BTW, mine has been running and driving all year with a built auto, it's a blast. The auto is MUCH bigger than the manual trans, but fitting it in there I actually didn't need to modify the GTO oil pan. It sits almost perfectly on the crossmember. Engine is a little high and forward from the manual swap, but still fits under the hood. Not sure if I can find room to run piping for twin turbos, I may just go big inch NA, nasty heads and a cam.
Love this swap, everyone should do it.
Sorry, since I built it I've been busy as hell all year, so you only get a burnout vid. Right now I'm tearing it down again to finish everything, and probably throw some more power in it. Only logged back on to look up Mikes info on the brake booster swap.
It was built CA street legal, but I moved out of CA, so... hahahahahaha. If you are building one and need all the smog parts or a GTO oil pan, hit me up!
Old 09-10-13, 03:26 AM
  #69
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
what a tease lol... lets see some pics..
Old 09-10-13, 11:19 AM
  #70
Dscustoms
Dscustoms's Avatar
It's a mess under the hood now, and before I had wires everywhere to get everything working, so I don't want to show that off. I'll give ya this to prove it though.
Old 09-10-13, 12:57 PM
  #71
i2ice
i2ice's Avatar
nice ls/auto setup seems ideal for a DD, i pm'd you some questions regarding your car Dscustoms
Old 09-10-13, 01:01 PM
  #72
Sevenevez
Sevenevez's Avatar
this is awesome. more more more
Old 09-10-13, 04:07 PM
  #73
Nverez4me
Nverez4me's Avatar
Dscustoms what trans are you using. Been hoping for someone to do an auto swap.
Old 09-11-13, 02:50 PM
  #74
Dscustoms
Dscustoms's Avatar
4l60E, Stage 2 from Performabuilt with a 2800 stall converter. Motor is from an 04 GTO, figured I'd do the swap cheap to start (AHHAHAHAHHAHAHA NOT.... Stuff adds up fast when you only use good / new parts) then put in a bigger cube LS down the line.
Old 09-12-13, 08:22 AM
  #75
repugnante
repugnante's Avatar
Wow, great stuff man. Really great stuff. Keep em comin
Quick Reply: FAQ: GM LSx Engine Swap into 91-2005 GS300/400/430 / 01-05 IS300 / 91-00 SC300/400
