Can I raise my engine via the oil pan? (motor mounts diy)
https://www.clublexus.com/forums/5824463-post29.html
I lifted the motor up an inch or so by the pan, no problems there.
It's not going to fall on you .
That was my first thought too, but like I said in the other thread, I could not break loose those bolts. I used an impact, I used a breaker bar, and they would not budge. I did not want to snap the heads of the bolts off, so I loosened the big nut instead. But if the OP can break loose those four bolts, it'd proably be an easier job.
So you're working on a V8 I'm assuming? (sorry didn't take time to readt entire thread).
I did it on my GS430 and it was very challanging but totaly doable!
You will have to lower subframe plus this will be the easiest way to go about it. Other way is to try to get the entire bracket off witnh mount attached to it. I actually have a thread on here somwhere with pics and yes you will have to raise entire egine about and inch or so:.
https://www.clublexus.com/forums/gs-...t-attempt.html
I looked down from the top and theres no way to access or hit those bolts. I have to look and see where the brackets are.
If I lower the subframe; will I be able to push it back up? Does it mess with the lower camber eccentric bolts at all? I just got a third alignment and dont want to mess with that if at all possible.
I have a few jacks to use and a few stands.
I'm going to sears tomorrow to get some extensions, swivel impacts and the mounts are already on order from sewell.
I did my tranny mount a few months ago and my vibrations went away for a bit. A few days ago I got back my shakes and I'm having a feeling this will solve the issue indefinitely.
I'll try to get pics if I can. Maybe a video.
Yeah, forgot to add -- its my GS400.
1) Raise the car
2) Raise the engine on oil pan
3') Loosen subframe
4) Loosen engine mounts
In this thread I have a pic of a 17 wrench I used to get to them.
Remember: safety first!
That package should have never left the shipper's hands, not with those mounts just thrown in the box with no padding. Embarrassing.
Good luck with Fedex, I nearly took them to court over a furnace they dropped at my door - dropped so hard that the bottom dented and the motor fell out. They said it was not their fault but the shipper's.
