Can I raise my engine via the oil pan? (motor mounts diy)
Alright so I need to do my engine mounts. I put car in drive and "brake boosted" it and stomped on the brake and my entire engine shifts badly. I will post a video later.
I've done almost all the work on my car on my own being that it rarely gets driven and I've done complete motor swaps (5spd to auto) so I am a bit mechanically inclined.
I don't have a engine hoist or a lift to lift the motor so I am resorting to doing this sort of half assed. I got a quote from a shop for $300 without parts.
If that's my last resort then I will do this. I just need to lift the motor with a bit if clearance one side at a time, just a but confused on how to do this. I was thinking about using a two by four making a "X" and using that to support the pan. I'll be dropping the pan too in order to redo the oil pan fipv.
place it under the transfer case with piece of wood... your asking for trouble with the oil pan which can bend or crack or just do one side at time by placing the jack on the bracket to the mount it self ,if it brokeing you going to left the motor and all it needed to remove the bolts place the new one on..bam on to the next one that a 3 to 4 hr job if you dont know what your doing
If you use wood and go slow you should be fine, did this on my old daily driver to replace worn mounts without a problen, granted that pan was cast aluminum it still should not be a problem with the GS stamped steel pan
In the SC section everyone who has done the engine mounts would suggest it to you. There's no stress on the pan as long as you do it slow with a wooden block between the jack and the oil pan. I recently did it on my SC cause my engine mounts were literally split in half in the drivers side and I wouldn't pay any shop $600 to do it when it's that simple and easy. I was able to change everything in like 2 hrs minimum. Although watch which parts are being pulled in the engine bay as you're raising the engine, like on mine I didn't check it initially and I managed to rip my intake coupler, given it's a 17 year old rubber coupler and it was really crunchy and dry already but it's like $60 OEM. But other than that my car have been driving like a champ ever since.
I want to do one mount at a time. I dont plan on removing both.
I'm interested to see how I can jack the mounts up by the brackets. Anyone have any pictures of this?
I'm kind of scared to move the transfer case as I don't want to disrubt the rear main seal in any way.
I'm going to try a towel under a piece of thick plywood the size of the entire oil pan. Drop the front subframe a bit and see what happens.
Anyone have pics of where to jack it up by the mounts?
Thanks!!!
I will drop the transmission just a bit, I wont take the bolts off though -- I'm not sure if thats a smart idea as I dont want to damage or move the transmission at all from the rear main seal.
I'm a bit weary of doing this -- but I like challenging ****. I just dont want my motor falling out of the car or on top of me. \o/
You can't do it one at a time, at least you can do is loosen both nuts from below the subframe. If you leave it bolted on one side then raise it the engine is gonna sit sideways and there's gonna be more stress to whatever's attached on the raised side. It's a pretty tight space you're gonna be working on, and you gotta be real creative on how to access the upper nuts of the engine mount.
