Is this bad?
Is this bad?
Wats up CL I have an 01 GS430 with 95k and when im idling in park and rev the gas as I let go of the gas you hear a rattling noise from the cat. I had a few exuast leaks that I got repaired which I though would fix that problem but it's something different. The muffler guy I know said "it's inside the cat and can't be fixed and is uneccesary to fix because it's just something loose inside the cat." he said it wont do any harm except for that annoying noise when revving at idle which i can care less about because it doesn't happen when driving thank god. So the question I have for you guys is, is he telling the truth? because I thought a rattling cat meant a bad cat which would cause poor performance and gas mileage. Could this have been caused by an accident from the previous owner?(even though he swears no accidents). Any opinions on what this can be is appreciated thanks
its the heat shield protecting the cat and the rest of the pipe.
its a common problem, just go under there and cut it off with tin snips or unbolt it if you can still loosen the bolts.
some examples from IS/GS owners
https://www.clublexus.com/forums/is-...tling-fix.html
https://www.clublexus.com/forums/gs-...converter.html
https://www.clublexus.com/forums/gs-...eatshield.html
Account under Legal Action - Banned
Youre in ny, so you need a cat converter to pass emissions. With a failed baffle inside your cat conv you are essentially rocking a straight pipe. You will not pass emissions the next time you have to renew. The catalyst within the converter is gone for you.
Search ebay or junk yards/craigslist for some.
In worst case your engine could "choke" as the cat could become blocked and limit exhaust flow out of your muffler.
Well it can't be the heat shield because when I got the exaust leaks repaired they removed the heat shield because we thought that was the issue but it seems to be coming internally from the cat. But funny you say that I just passed inspecton yesterday with the cat like that and i do not have a check engine light on. Is it possible that something is loose inside the cat but that the cat is still good because the car seems to be running fine
And as I said before it ONLY makes noise when im parked and I press the gas. As I let go of the gas you hear a rattling coming from inside the cat. When I'm driving I dont notice anything
If you didn't have the heat shields removed I def would've said that's your issue, was for me, but try replacing headers completely one of he members can pass the inspection (Jeff) and he had his car boosted......or take the headers off and shake it until the loose part comes out lol
personally i would go and remove all the shield below from the Y pipe back to the midpipe and check it again to see if the sound continues.
