2001 Speed Sensor (VSS) Wire Color
Hey Guys going to feel like an idiot, i've been searching around on here and yahoo getting fed up on looking thought i would just ask maybe someone could answer it faster for me.
I installed the AVIC Z130BT a few weeks ago was doing some additions on the car thought i would go ahead and wire the speed sensor (VSS) for the nav (i know should have done it earlier but oh well lol). Now i've heard the Green wire behind the gauge cluster on the 18 pin connection but there are two, and then saw the purple/white under the steering wheel area.
What wire is it exactly? 2001 GS300.![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
Appreciate all the help i'll take the complaints about asking again lol![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
Thanks a head of time.
After some more tedious searching lol i found an answer going to have to try it tomorrow.
Thanks Kidd1 - if u have a gs 430 then its purple/white by the power steering ecu, The power steering ECU is between the driver kick and the ABS ECU.
if its a gs300 its red/blue 17 pin plug, pin #11, Located inside ECU box which is under hood on the drivers side.
So see if that answers my question. I'll post it up tomorrow for you guys appreciate everyone.
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
The GS VSS sensors your dealing with are on the transmission, they feed the engine ecu for shifting purposes.
The Speed sensor he is talking about is for the vehicles actual rolling speed that is displayed on the speedo, which is also tied into navigation systems, which is what he is trying to get hooked up.
The Speedo MPH signal is a feed that originates from the wheels ABS sensors, then to the ABS/VSC/TRAC ECU, then feed out to the Speedo, Power Steering Ecu, and Navigation Ecu (if equipped)
Here I highlighted the circuit your looking to tap into.
![](https://lh3.googleusercontent.com/-lTWXHM1vsS8/TzcqzMnblDI/AAAAAAAABK4/H7l-1z6BAXs/s620/VSS%2520Speed%2520Sensor.jpg)
Oh, and you mentioned there were two green wires at the speedo connector. This is correct, the other green one is the feed to the VSC warning light at the bottom of the cluster. If you have the cluster out of the car you could easily eliminate which wire this is by checking continuity between the where the bulb holder for the VSC light gets power from the circuit board to which connector pin the green wire is on, and then that means the other green wire is the SPD... But it's easy enough to get to the violet-purple wire down by the brake pedal.
Here is the other green wire on the cluster:
![](https://lh3.googleusercontent.com/-9elbvTSHLsI/TzcuF_Q0nvI/AAAAAAAABLQ/jz0tanKvYpM/s447/cluster%25202.jpg)
You posted this same issue in a different thread. And that's fine, but understand what he is doing doesn't pertain to your issue.
Oh ok my bad yo I know how it gets when people make new threads about things that have Been already talked about but at this point I might just have to do that.... I've posted On a few other threads trying to find Answers. All I'm Trying to do is find a solution that's all. Thanks for explaining to me the Differences thou
https://www.clublexus.com/forums/7010800-post78.html
bklynboi
03-25-10 08:53 PM
jucee187
08-19-04 09:21 AM
