'00 GS300 Fuel Pump issue? Need some guidance
Old 10-11-11, 07:04 PM
gman44116
gman44116's Avatar
Originally Posted by GS4_Fiend
Your fuel sending unit/float is no good.
Any idea which one I should be replacing? There is the main attached to the pump housing and a sub sending unit on the other side of the tank??
Old 11-30-11, 04:31 PM
Neo
The One
Neo's Avatar
Just bumping this up to see if OP ever resolved this. I have a similar issue with my fuel gauge where it is erratic. My shop thinks the sending units are bad. I've been meaning to find time to open up the tank. Does someone have part numbers for all the various replacement components? Just in case, I have a 98 GS300. Thanks.
Old 11-30-11, 05:02 PM
gman44116
gman44116's Avatar
Post #15 reflects where I left my situation. I replaced the fuel pump and fpr which seemed to take care of my issue running out of gas with a 1/4 tank on a road trip.
I have basically replaced everything but the sending units (floats). There is actually two of them, one on each side of the tank. Definitely is a DIY. I just got used to the gauge. When it is on 'E' that means EMPTY!!
My suggestion is to replace your sending units. Start with the one on the fuel pump housing. While your at it go ahead and replace both the fuel filters on the main pump. if that doesn't work replace the reserve sending unit.
Let us know what works when you've taken action. I'm still interested in finding an answer without spending anymore $$$ on it.
Old 04-04-16, 10:32 AM
tiguy99
tiguy99's Avatar
Did you ever replacing the floats? Also did replacing these parts stop your running out of gas problem permanently?
Old 04-04-16, 01:59 PM
Mcon
Mcon's Avatar
I know this thread is old, but to tiguy99,
tiguy99; Did you ever replacing the floats? Also did replacing these parts stop your running out of gas problem permanently?
I change mine a few week a go. Take me like 30 min. total is not that complicated. Is very easy to do. The passenger side is one electric plug and 6 screws. Driver side, is 3 10mm nuts with electric plug and a yellow clip that you need to pull out to take out the gas hose. Them 8 screws 8mm and pulling out gently. The driver size float is attach to the base by 2 clips. If I can I take pictures tomorrow and post here and that way you can see it.
Also, maybe when gman44116 put the gas pump back, the gas line is on top of the float and that is the reason way the float or gauge no read correctly. That happen to me when I change the gas filter on the pump. Have to be careful when re install the pump back. Is very easy to miss that.
Old 04-05-16, 12:52 PM
tiguy99
tiguy99's Avatar
Thanks Mcon...seeing your car pics would be great
Just got the car Sunday.
Haven't touched it since the tow truck unloaded it
Here's my thread with more details
Old 04-07-16, 05:19 AM
Mcon
Mcon's Avatar
tiguy99,
Sorry for the late replay to you.
Just remember how the back hose go before pull out complitly the fuel pump assy. Again, remember, be 100% sure when you take the pump out, look carefully as this black gasoline hose, if is on the top of the gage or below the gage. It is not so hard to do. Just, look closely at what you do and then re reverse the process. Take pictures to remember you if that helps you in the process. I'm here to help if you have more questions. Good luck and sorry again for the late replay to you.
This the passenger side. (The top) . Is oly 5 screew and one wire plug.
This how look bottom part. The part that go inside the tank. Passenger side. OEM Part # 83320-80362
Driver side Pump and the gage assy fuel. Look very well the picture because I have the plug basically put out already that's the way that you need to take it out. Both clips out and pulling down. That simple. Also, on the right side of the picture, you see a black plastic buttom, there is where the black hose go with a clip, pull the clip out and the fuel hole out and you get the fuel pump out like I have on the picture and change the gage assy fuel more easily.
The only that you need to pulling out is the 2 clips on top and one on the center of the full pump assembling and pulling down and put the new one in. That all you need to do.
OEM Part # 83320-30500
OEM PARTS #.
Old 04-07-16, 07:15 AM
tiguy99
tiguy99's Avatar
Thanks again Mcon!
Old 04-07-16, 07:24 AM
Mcon
Mcon's Avatar
Np.
Old 04-07-16, 02:28 PM
lextout
lextout's Avatar
always put gas in when the fuel light comes on, dont wait another mile, running low damages the fuel pump.
what i do is always fill up when it gets to the half tank mark that way i always have a fuel tank
Old 04-07-16, 06:22 PM
Mcon
Mcon's Avatar
tiguy99,
I forget to mention to you, when you to this, do it with 1/2 tank o less, because if you do this with your tank full or 3/4 full when you take the fuel pump assy out, the gasoline coming out like one full gallon. So, is better to do with half or less gas on the tank.
Old 08-25-16, 04:40 PM
Paul1307
Paul1307's Avatar
This is beginning to seem like it's a lot more common than I first thought. Please check the thread below.
https://www.clublexus.com/forums/gs-...15-code-2.html
Old 08-25-16, 07:31 PM
Mcon
Mcon's Avatar
Hi Paul,
First., Thank you for do that.
Second, Are you see the thread is a few months old.
Third, Tiguy99 Member is in that thread as well.
But again, Thanks for the input.
Old 08-26-16, 11:27 AM
tiguy99
tiguy99's Avatar
Yeah Paul explained this very well.
Going to try the gas cap method from his thread above.
Also, I got the P0446 EVAP code as well.Looks like I maybe replacing this soon as well
Old 08-29-16, 01:27 PM
Paul1307
Paul1307's Avatar
If the vehicle runs out of gas, any code would be a secondary effect and not to be trusted. On the other hand, if with a gas tank anywhere from 1/2 to full the code pops up, then I'd take it seriously.
ATLs400
08-29-19 05:17 AM
Hamo808
06-01-17 06:10 PM
semar
06-22-16 09:42 PM
thegr8one
11-16-10 01:22 PM
COOLIS
01-17-10 09:06 PM
Quick Reply: '00 GS300 Fuel Pump issue? Need some guidance
