Emeregency brake light comes on
Old 09-24-11, 06:06 AM
flossabe
flossabe's Avatar
Default Emeregency brake light comes on
Every once in a while my emergency brake light comes on when I am braking but it is not the emergency brake pedal that is causing it. The e-brake pedal doesn't have any unusual play in it and it activates the light when engaged but it doesn't seem like it is the switch on the pedal that is causing the problem. I haven't noticed any other braking issues either. Anyone deal with this before?
Old 09-24-11, 06:21 AM
newgsman
newgsman's Avatar
Have you checked your brake fluid level?
Old 09-24-11, 07:26 AM
Johnny Rad
Johnny Rad's Avatar
Parking brake might need to be adjusted. No big deal, I think.
Old 09-24-11, 01:17 PM
JeffTsai
JeffTsai's Avatar
As newgsman said. Check the brake fuild level. If that's low it will light up on the dash.
Old 09-24-11, 03:05 PM
V8drummer
V8drummer's Avatar
My SC did that before. Front brake pads were running low, so more fluid has to be used to depress the caliper.
Old 09-24-11, 09:06 PM
L3XOTIC
L3XOTIC's Avatar
Low fluid or needs a simple adjustment
Old 09-24-11, 09:47 PM
flossabe
flossabe's Avatar
Cool I'll check it out tomorrow
Old 09-24-11, 09:59 PM
GS4_Fiend
GS4_Fiend's Avatar
brake pads low, brake fluid, or even poor brake fluid distribution (clog lines and such).
Old 09-25-11, 02:47 PM
CTGS
CTGS's Avatar
I had the same problem mostly in the winter months, I added brake fluid and it hasn't happened since.
is250Gwong
04-24-15 05:15 PM
carbonlexi
Suspension and Brakes
04-14-12 12:26 AM
Emilio253
SC- 1st Gen (1992-2000)
08-04-10 12:15 PM
sssjumper
11-01-09 08:06 PM
minh
GS - 1st Gen (1993-1997)
04-21-03 10:36 AM
Quick Reply: Emeregency brake light comes on
