Slammed on 7-series BMW concave wheels
Old 11-26-12, 05:25 PM
  #286
BayAreaLex
BayAreaLex's Avatar
As mentioned above, the lower your are, the more it will camber/tuck...
When I was on NF210 springs (modest drop), it looked like my BMW wheels were sticking out. Then I dropped it on coilovers and it tucks (245/265 tires too).
Old 11-26-12, 07:47 PM
  #287
abounly
abounly's Avatar
This is true, BUT if you can't get the tire/rim to clear the fender even if you slam it to the max it won't do anything.
Old 11-27-12, 07:51 AM
  #288
Bippu147
Bippu147's Avatar
Originally Posted by RikTT
Anyone running TT or LS brakes on them and also what RCA's ?
I ran TT brakes with my Style 95's. I was also running the 19mm wheel adapters.
Old 11-27-12, 02:47 PM
  #289
RikTT
RikTT's Avatar
Should have mentioned re-drilled ones over them ?
Old 12-04-12, 01:59 PM
  #290
BayAreaLex
BayAreaLex's Avatar
Is that what he did? I only saw the attempt at way above "slammed" height.
Old 12-05-12, 05:27 AM
  #291
John9689
John9689's Avatar
Well you were right they do tuck when your slammed, only trouble is I got stuck trying to get onto my friends driveway
Old 12-05-12, 10:20 AM
  #292
BayAreaLex
BayAreaLex's Avatar
I knew it ;-)
Looks to tuck nicely. You can do a little clearancing or stretch that tire a little more and you should be good to go.
Old 12-06-12, 12:30 PM
  #293
1sWt2GS
1sWt2GS's Avatar
can any1 confirm if these will rub without fender mods?
(redrilled style 95's)
Old 12-06-12, 01:28 PM
  #294
BayAreaLex
BayAreaLex's Avatar
That depends entirely on your tire size and ride height.
With my 245-35-19 and 265-35-19 tires and Megan coilovers (1 finger gap), I ever so barely clear with tightly rolled front fenders and rear lips that have been pretty much completely shaved off... And I mean it barely clears.
It would take pretty narrow tires to clear with no fender mods (like 235-35-19 all around for example), and even then it will be close assuming you are low.
Of course, everything above is assuming redrilled with no spacers.
Old 12-06-12, 04:20 PM
  #295
1sWt2GS
1sWt2GS's Avatar
so you'd have to stretch to fit these ? fatter tires definitely wont fit without fender mods?
Old 12-06-12, 04:50 PM
  #296
BayAreaLex
BayAreaLex's Avatar
No that's not what I said. I would stretch if I am trying to avoid fender mods. Not even sure if that would be possible because the offset on these rims is fairly aggressive.
With an aggressive fender shave front/rear, 245/265 fit nicely.
I've even thrown around the idea of widening the rears to 19x12 and doing a 295-30-19 (widening towards the inside)
http://www.weldcraftwheels.com/
Old 12-06-12, 10:25 PM
  #297
mk2tmr2
mk2tmr2's Avatar
For people looking for center cap options, you could always hit up a company like www.r2-limited.com and they might make them for you. They do custom center cap badges (faces) for lots of Miata guys.
Old 12-07-12, 07:16 AM
  #298
cruisinvip
cruisinvip's Avatar
excuse the foglight
Old 12-07-12, 07:58 AM
  #299
mk2tmr2
mk2tmr2's Avatar
That looks really nice. There's a set of these for sale in dallas - with good tires - for $599 at a pick and pull. You guys are tempting me. It looks very OEM.
Old 12-07-12, 08:52 AM
  #300
cruisinvip
cruisinvip's Avatar
Thanks, found a few more.
Quick Reply: Slammed on 7-series BMW concave wheels
