please help on remove the weatherstrip seal door around the door !!??
well like the title said me and some other member from here trying to figure out how to remove the weatherstrip seal from the drivers door without removing the door, is the one it goes around the door not around the body on the car can some one help us out and if u have a video better well i hope i get some help cus ineed that seal cus some one rip it trying to opend it from the top door
The best place to start is at the bottom. Just pull the pink clips out. You'll have to remove the door strut arm thingy (real specific, I know). Just take the plastic cover off of it and slide the pin out.
The door panel doesn't have to come off or any of that nonsense. Just pull straight down on the rubber and you'll see pink clips pop out. Work your way around the door.
How much do brand new ones go for? I need to replace my soon, the idiot before me ****ing painted over the stripping and now its starting to crack, looks like someone went over it with a permanent marker.
Where can i get one new and i hope is not to expensive hahaha i guess u going to said in the dealer but o well let me get the info if u have it bro
DixonPai
05-31-09 04:00 PM
2001, clips, clublexus, door, doors, is300, lexus, rear, remove, removing, strip, weather, weatherstrip, weatherstripping, weatherstrips
