Alternator and ABS/VSC/VSC OFF Lights
Okay, I've searched and read as much as I can on this issue and still don't have a handle on what is the cause of this situation. Here is a summary:
Here's my situation.
98 GS4 184k. No suspension work in last 12 months. Stock suspension. No leaking fluids
2 1/2 months ago car wouldn't start one morning. Jumped it and took it to have the battery tested. Tested good but needing charge. Charged battery and all was good.
4 weeks ago same issue. Cleaned terminals, added distilled water to battery and put on charger. Wouldn't take a full charge so installed a new battery.
Last week started the car and got a loud humming noise from engine. Humming speeds up with RPM but gets quieter after motor runs a while. (Traced the humming to the area around the P/S pump and/or alternator.) On my way home the VSC, ABS and VSC OFF lights came on. Car seemed to run fine. Got home, shut off car and re-started. No VSC, ABS or VSC OFF lights came on. All is fine except for the humming noise is back when engine is cold.
Now after a week I've had three more instances where the ABS/VSC/VSC OFF lights have come on and stay on until I restart the car. Car seems to run fine regardless of what the lights might indicate. NO CEL.
Today I took the car and had the alternator and battery tested. Battery fine, alternator showed "Open Diode" (whatever the hell that means)
The guy doing the testing said I most likely have an intermittent issue and that the alternator is working but to get ready to replace it.
I know somebody will suggest checking the speed sensors and I will check to see if there are any codes but since the suspension hasn't been touched in a very long time I kinda doubt they are the issue unless they failed on their own. Haven't really read where this happens.
What say you?
What say you?
boombastic
04-29-20 01:42 PM
