HID brightness..
#31
The bike looks good ^^^^^
OEM HID complete housings into a NON-HID GS is not a problem as far as powering the ballasts, it's just the Auto-Leveling feature that won't work, and the HID housing still has manual adjusters to aim them properly, auto-level is not required to install and function..
The other common option is to just install the bare HID reflector bowl into the NON-HID housings, which is an easy swap out. Then just use a D2R bulb and aftermarket ballast. And aftermarket ballast could be used in full OEM HID housings as well if desired.
#33
Man o man. So much miss information here. PNP kit in non hid housing = glare. I have been doing custom lighting for over 8 years. The hid counter part is setup completely different. Unless u can limit the light from hitting the bottom of the bowl you are creating glare. Please for the love of god read and make a educated choice from there. A retro would be the best thing to do .
#34
I will purchase a slim 35W digital ballast. It runs much cooler than 55W and doesn't burn out the bulbs (as quickly). I had the first gen Jeep SRT8 and the bulbs went out it pretty quickly. (Boy, was that car fast.)
#35
Thanks everyone for your input. I'll make sure to post photos when done.
Best regards.
#36
If u are truly going to put the kit in, find a way to block the lower part of bulb. That will kill some glare.
#38
#39
#40
#41
Now this is only for 5000k, cause I like the blueish/white tint anything Kelvin higher is too much. My taste is a little bland....I don't even like HID's in the fogs. I preferr 4100k halogens. 4300ks HID's will have the most output regardless of Wattage....but I only wanted 5000k. I had the 35W kit with a relay in my 05Jeep. I Liked it but then bought a 50W kit. The 'is" a little more light to the ground. On coming traffic sees about as much as a TSX projector......which are bright, but acceptable. The 50's are in projector lamps and have not melted any plastic in the headlight housing. Maybe small headlight housing trap so much heat they melt. I have also read the 50 watt kits are merely 35W bulbs being "overdriven" by a 50W ballast. I have had the 50W kit with a relay kit in my Jeep for two years and have had no problems, just complements... hope this helps.
#42
#43
As suspected, labor is what's stopping most people from swapping out the reflector. Unless you want to go through the hassle of baking the headlights and properly sealing them, it's easier to find OEM HID housings and then sell your non-HID. But if you're going to take apart the headlight, you might as well do a projector retrofit.
#44
#45
Changing focal points without altering the pattern of the light beam.. Ah yes.. plug-n-play kits have defied the laws of optics.
I've noticed that when my friends first got their hands on a set of aftermarket HID kit for their non-HID housings, they thought it was the best thing ever. Of course, they wouldn't admit to the glare issue because the kit was their new toy. To them, it wasn't too bad but of course they were a bit biased. Fast forward a few years, I did a retrofit for them and now they clearly see the light (no pun). It's one of those things where you think back and say "WTF was I thinking!"
