Just installed BOV but now CEL?
ok so i finally got my BOV Flange welded and installed the Vortech Max flow BOV on before the MAF so i can just vent it.. everything went well and sounds great until my CEL pops up and my car doesnt feel 100% anymore.
My brother ran a scan and found that the Knock Sensor 1 code was showing.
could getting a BOV destroy my knock?![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
CODE: P0325
CODE: P0325
How far away from the maf did you mount the valve? My bov is on the hot side of the intercooler just after the turbo and the maf is on the cold side just before the tb so there is plenty of distance between them to minimize turbulance/air flow changes on the maf. I've had no issues with knock at all.
Did you clear it and run the car somemore and see if the knock code came right back again?
i got the flange welded after the intercooler.. which is the cold side i guess
.. DAMMIT i knew i shoulda had it welded before the intercooler..
![](https://a7.sphotos.ak.fbcdn.net/hphotos-ak-ash4/312572_10150281804563227_576428226_8019747_5500267_n.jpg)
Its on the shortest pipe out of all my piping.. near where my foglight would be. the small 45 degree style pipe.
![](https://a1.sphotos.ak.fbcdn.net/hphotos-ak-ash4/s720x720/295864_10150331978713227_576428226_8318466_963580649_n.jpg)
I cleared it about 3 times. and the CEL keeps popping up. I even tried removing the SAFC tune and running with the stock ECU with no piggy and the code still pops up.
I guess my knock sensor took a poop?
The purpose of a Knock Sensor is when it sense the engine knocking, it will retard the timing until it stops knocking. Also, if the Knock Sensor gets a vibration, that too would cause the knock sensor to go out of whack and retard timing. Isolate the vibration, returning back everything to previous was, if could still pops up, then KS is bad.
good info.
Ok so i reset the car again and this time ram the car with the BOV vacuum line off (pretty much doesnt let it open)
the CEL didnt pop up yet
then i put back the hose and after drove it less than 100 meters n bam CEL is on.
im going to drive it without the hose for a little longer to conclude if the BOV is causing this. There is a way to tune it with the BOV right via the SAFCII??
ok drove the car some more with the BOV disconnected and the CEL finally popped up again :|.. i think my knock sensor died or something.. car runs sluggish and i can feel it shuddering as the RPM increases. FML
guess its now time to remove the whole intake mani and replace knock sensors??
question now is... OEM or parts from Amazon? lol
Mortgage Slave
Hang on, you have your BOV mounted before the MAF? Wouldn't that cause the MAF to send the wrong voltage signal to the ECU, hence the car throwing a fit?
Have you tried plumbing the BOV back into the piping so it recirculates the air as opposed to venting?
i haz no idea.
i have a feeling it might be coincidental since... my car started to fall apart after boost LOL
FML
ive read mixed things about BOV placement... i.e. best to put it on the cold side.. or best to put it on the hot side. i just copied LALEX's placement LOL also iono if its better to have the air move a smaller distance towards atmosphere (cold placement) vs going all the way back through the intercooler and more pipes before vent (hot placement)
You shouldn't really have stall issues in blow-thru, most people with stalling issues are typically running pull-thru pre turbo mafs and blowing off.
If moving placement of the BOV has a substantial effect on a setup there are usually other issues like a poor source for vacuum or to small of a vacuum line used, too small of a bov for the turbo, or if a spring based unit like a tial maybe the wrong spring selected for the -hg the car pulls.
