i have a 98 gs300 and randomly my vsc and vsc off lights will come on but no check engine light and the car seem to drive fine no change in it and when i turn off my car and start it back again everything goes back to normal what do you think is the problem? help pls
i been on here for 4/5 days and i have read alot lol sounds like speedsensor even tho theres no light on the dash but i also learned that if its driving fine DONT worry about it until you notice any weird actions
Not the best advice in my opinion. What if that "weird action" is no ABS or VSC in a emergency situation where it is needed?
Sincity702 - Do some searching AND get the code checked. Your car will store the ABS code even if the warning indicator is not on. You will need to take is to a shop where they have a higher end scan tool. Basic OBDII scanners will not access the ABS.
