High Mileage Club
Old 09-17-17 | 06:14 PM
  #196
RamAirRckt's Avatar
RamAirRckt
I run Amsoil Signature Series oil, I had been running 0W20, but moved to the HDD Diesel this time (5W30). I ran Valvoline titantium synthetic (the older formula) and changed it at 10k and did oil analysis and it was worse shape overall than the Amsoil is at 25k. I run an Amsoil EAO26 filter (BIG, aka, very big...) and fill with 7 quarts. Its interesting, the oil when sits overnight shows way high, start it and run for a while and then shut off for 10-20 min and it reads spot on full. I typically don't have to add oil till I get around 20k miles, then I usually add a half quart. VERY solid engine. Amsoil oil is the bomb for long drains.
The oil analysis is the key. If I showed it not performing at 25k then I would shorten, but it is always good, its getting tired by 28k to 30k, at 30k was on the edge of oxidation. So I found my limit with this engine. My thoughts are that running an oil cooler (2UZ-FE cooler is in the works, but not installed yet) and an Amsoil bypass filter I bet I can get to 50k on the same oil. But oil analysis is the key to run it, will have to run a UOA at 25k and see how it tests first.
Originally Posted by kevin3344
Amazing! What oil do you use? I've been using pennzoil pure platinum synthetic for years and usually change it every 5,000-6,000 miles....but maybe I can go longer?
Not really. I do oil analysis to see. The oil is ending its life, but not sludging and oil still within viscosity.
Originally Posted by GITAdriver
25k dammm it must be really black at that mileage
Old 10-09-17 | 08:01 PM
  #197
wbmx1981's Avatar
wbmx1981
Hit 290K today. Just did the upper control arms on Sunday.
Old 10-09-17 | 08:56 PM
  #198
RamAirRckt's Avatar
RamAirRckt
I'm off on my car for the last 3 weeks due to surgery but then back on the road again..... I've put over half of the miles that exist on my car. Still this car has lasted me 2x as long as any GM car.... And the Lexus Gs400 is still chugging along well.
Old 10-09-17 | 09:29 PM
  #199
RamAirRckt's Avatar
RamAirRckt
Old 10-10-17 | 08:53 AM
  #200
Angryspice's Avatar
Angryspice
222k here. But to me thats new lolol
Old 10-10-17 | 01:39 PM
  #201
1QWKGS4's Avatar
1QWKGS4
I guess I can't get into this club.. Both my cars still under 50K..
Old 10-11-17 | 07:35 AM
  #202
Rock-a-Lex's Avatar
Rock-a-Lex
Hi all. I just hit 133k on my ride. Had her since 2002 with 42k.
I have a quick question. I remember getting my timing belt done at the local dealer at around 80k. Does this mean I'm good until 160-170k or should I replace it again sooner? Are there any sign of a worn timing belt?
Also, does being supercharged have any effect on timing belt wear?
Thx
Old 10-11-17 | 08:13 AM
  #203
ZanderZ32's Avatar
ZanderZ32
Hit 237k today, just over 15k since I purchased it in Feb 2000 GS400 and its been bullet proof
Old 10-11-17 | 05:13 PM
  #204
twsti321's Avatar
twsti321
2001 gs300 with 248xxx..
Old 10-17-17 | 12:21 AM
  #205
FanboiFrsh's Avatar
FanboiFrsh
My 99 160 is at 285,xxx miles she runs amazing and is purdy!
my 93 147 has 230,xxx miles and is doin just fine
Old 11-03-17 | 06:58 PM
  #206
BrianHT's Avatar
BrianHT
My first foray into the luxury world, 1998 GS300 with 188K. Now it's a year later, 194K. Feels like it could go forever.
Old 11-05-17 | 07:31 AM
  #207
MDMXLX's Avatar
MDMXLX
Were they squeaking? My car sounds like a stagecoach!
Old 11-13-17 | 05:30 AM
  #208
Howells's Avatar
Howells
440k here on 98 gs4
Old 11-13-17 | 05:49 AM
  #209
"Lexappeal's Avatar
"Lexappeal
Originally Posted by Howells
440k here on 98 gs4
wow....you still on original motor and trans bud?
Old 11-13-17 | 05:50 AM
  #210
Howells's Avatar
Howells
yes all original. And still strong
