what should i put in my 2002 gs300 to get alot of HP??
the JDM aristo COMES with twin turbos...
not to mention here is adrians old car WITH a twin turbo setup, most people choose to go single but a twin setup will fit
you really need to do some research and decide what your goals are and then build your motor around those goals (not just highest hp but what are you wanting to do with it), there isnt a magical answer to your ?
I raise your twin turbo.. with..
Tri-turbo
Alloys999- There is a plethora of information on this site... some people get annoyed when new members ask broad questions because they think you haven’t searched or done any research, and essentially it comes off like your asking others to do the leg work for you. Anyhow, the BEST single turbo, that was designed for the 2JZ, is the HKS T51R... you have to realize that making BIG power that is sustainable is not cheap... as well as the fact that you will need to beef up more then just your motor... transmission/drive train etc. It’s a long expensive road, but if you ask me, its totally worth it.
Good luck on building your 2002 GS300, and keep us posted as you build it so we can follow along and help you out if you need it.
For some people a GT35 would work better than a T51...it's not based on the engine, just the application it's used in, and the results the end user wants.
im also guilty of early unsearched thread questions... but this reply is still funny
you'll learn quick OP its important to research everywhere before asking a vague question. it's like an open ended roast... the Search feature on here is the best tool... since ur new to CL like me you'll find almost ever answer somewhere on CL cause the veterans have already covered it... i just saw my first Tri-Turbo on here lol.
good luck bro
