what should i put in my 2002 gs300 to get alot of HP??
the JDM aristo COMES with twin turbos...
not to mention here is adrians old car WITH a twin turbo setup, most people choose to go single but a twin setup will fit
you really need to do some research and decide what your goals are and then build your motor around those goals (not just highest hp but what are you wanting to do with it), there isnt a magical answer to your ?
Ahhhhh
Also now a days anything is possible...
What my friend Sakataj said.... But as for OP you can also go single. Big single instead of 2 small twins and get more power.
With a set up like this ^^^^ You can do damage.
it depends on what you want to do...if you keep the current engine then you can turbo it or you can go 2JZ-GTE swap and keep twins or go big single...which ever way you will be way faster than stock...
