1999 gs3 vsc n vsc off light on small lag help me out please!!!!!!!
i have a 1999 gs3 a couple of days ago my vsc and vsc off light came on my dash board also my check engine light didn't think much of it till it started to lag when car was hot and the acceleration would lag i would have to stomp on the gas pedal to get any power. long story short i took it to my mechanic he cleaned out my throttle body see if that made a different s which it didn't lol so then he put the diagnostic machine to read the codes from the check engine it was giving 4 different codes that had to do with the throttle body two of those codes where the ones for the vsc so he said instead of replacing the sensors to buy the whole throttle body complete from a wrecking yard so i started looking around found one throttle body complete with all the sensors for 225 cheapest anywhere in LA so my question is what do you guys think should i go with replacing the whole thing and does that seem like the whole throttle would be the problem thank you.
Anytime you need help. There's a big search button above. Try using it.
https://www.clublexus.com/forums/gs-...eleration.html
