Steering rack help
Is anyone here using a rebuilt or aftermarket steering rack?
Im wondering because im pretty sure that i need a new steering rack because ive replaced almost everything in the front suspension except the rack and the tierods.
So can anyone tell me if replacing the rack with one from like ebay or rock auto would actually even make a difference in sloppiness and wandering or would it be pointless
p.s. Ive changed lbjs, endlinks, both caster arms and upper control arms
I had my car aligned about a month ago and the specs were fine
wouldnt they have noticed if something was wrong with the inner tie rods or would it be difficult for them to tell?
The issue that causes steering rack slop/looseness over time is the worn rubber bushings that hold the rack in place. Rack rarely needs to be replaced, rather just the bushings. It's definitely a maintenance item that should be done as the car creeps to100k miles or gets past it. I have a 2002 GS430 with 112K miles and your situation reminds me of mine. Loose steering, wandering,sloppy rack,alignment always going out. I replaced the whole front suspension just about (upper/lower control arms/caster arms, lower ball joints, outer tie rods,shocks). Still didn't resolve it.
2 months ago i ordered steering rack bushings from Sewell Lexus(a modified stiffer polyurethane bushing remodeled for the GS due to the rubber bushings wearing and causing steering rack slop). These are genuine Lexus rack bushings made for the GS. Also ordered inner tie rods because these are a must replacement and you can't really tell if their bad or not underneath the rubber boot. Replace these parts and get an alignment and you will be a happy camper
Here are the rack bushings $31.96 from Sewell Lexus:
http://lexus.sewellparts.com/accesso...2002/4558.html
Here are the inner tie rods $103 per side discounted for clublexus members:
http://lexus.sewellparts.com/oem-cat...S430-2002.html
END SUB-ASSEMBLY, STEERING RACK Part No. 4550339155 Quantity 2
Sewell Lexus is the best place to order genuine Lexus parts and they are much cheaper than the dealer. If you register on the Sewell Lexus website and state that you are a clublexus member, you get an additional discount on top of the the lowered prices.
Thats the kind of answer i was looking for^^^^^^^
So basically I should just do the inner and outer tie rods and get the sewell bushings?
I have a 98 gs300 with 89k is it common for the racks to go bad on these because i'm hoping the problem is alittle less serious that the WHOLE STEERING RACK but i don't wanna replace the tie rods and get rack bushings if they aren't gonna help at all
I JUST WANT MY CAR TO STOP WANDERING AND STOP FEELING SLOPPY
Rack bushings+inner tie rods+outer tie rods=guaranteed happiness
Car will feel like new, ride better and track straight.
Sewell Lexus is the best place to order genuine Lexus parts and they are much cheaper than the dealer. If you register on the Sewell Lexus website and state that you are a clublexus member, you get an additional discount on top of the the lowered prices.![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
I did notice on the packaging of my rack bushings that i ordered from Sewell that it stated "Problem Solving Rack Bushings", so Lexus must have at some point noted that the stock bushings that are in the GS have a problem or could be improved upon.
Yeah man thats what i would do. You're almost there, you've replaced the whole front suspension just like me EXCEPT for what is the culprit. I was throwing parts at the car too aimlessly from reading threads on here on what the problem would be. It's those rack bushings and inner tie rods. Especially on a 98 GS getting close to 100K those rubber rack bushings are probably deteriorating and causing the rack to move which is where the slop is coming from. You DO NOT need to replace your steering rack! Thats what the dealer will tell you because that's how they make money! That's what they told me. $1700 for a new rack because they couldn't find the bushings for the rack to order. But the rack bushings are $30! You do the math.lol.
Rack bushings+inner tie rods+outer tie rods=guaranteed happiness![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Thanks
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
I get more enjoyment out of helping someone else rather than simply typing "Search". Really helps to promote a sense of community here so visitors and new users won't think Lexus owners are nothing but selfish stuck up ******. Sure he could have searched for steering looseness but then he could have gotten a million threads leading him on a wild goose chase dealing with alignment, tie rods, Daizen control arm kit etc. Throwing money and parts at the car! Nothing sucks more than spending your hard earned time and money at a shop replacing something that isn't the culprit then driving off with the same problem. I've been there and want to help other folks not go through the same thing i went through.
Thanks ![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
Guide on Replacing the Steering Rack Bushings:
https://www.clublexus.com/forums/sus...k-bushing.html
Video on Replacing Inner Tie Rods
http://www.youtube.com/watch?v=5MJOt...feature=relmfu
Video on Replacing Outer Tie Rod Ends:
http://www.youtube.com/watch?v=o41XW...feature=relmfu
Get a good 4 wheel alignment afterwards
DJ8684
GS - 1st Gen (1993-1997)
08-10-14 02:47 PM
