VERY Major issues... CEL Blinking
Old 11-05-11, 09:02 AM
KingNasGS4
KingNasGS4's Avatar
Ok guys just an update even though I know this thread died.
The OCV definitely solved the issue and right now everything seems to be good. cost me 125 for the part and 50 for labor.
A lot cheaper than I thought
Old 11-05-11, 12:44 PM
FrankT
FrankT's Avatar
Thank you for the update! I never would have thought the OCV would be the problem.
I lost count on how many times the OP never comes back, on his own thread, and post a final resolution. Those threads are worthless. And this one is golden.
Old 11-05-11, 12:48 PM
GS4_Fiend
GS4_Fiend's Avatar
Yes this has happened before. Az-dave made a post about this
Old 11-15-11, 12:53 PM
8TREYLOC
8TREYLOC's Avatar
what shop did u go to , my car is doin the samething now?
Old 11-15-11, 01:12 PM
-Future-
-Future-'s Avatar
wow that was a cheap fix. My car recently had the same problems, I had to get new spark plugs, wires, valve cover gasket (leaking oil), intake gasket, throttle body cleaned, de-carbonation and something else....Anyway I got raped on labor, but I could of barely drove the car due to sputtering...But now my CEL is back on after the repair...Car is driving great but throwing codes P0153 and P0150......Getting frustrated....
Old 11-15-11, 09:11 PM
jonyboyyy
jonyboyyy's Avatar
bro i had the same problem with my gs300 03 sports design...
i would alway pull up to a stop sign & the car would start sputtering & bogging out, engine light blinking & everything...
scared the crap out of me!
sometimes the car completely bogged out & turned off !
we checked everything, MAF sensor, air intake booth, everything !
turns out the problem was that my COIL PACKS went bad, one by one..
i replaced one that soon enough the next one went out.. all in all you can pick some up from o'reilly for like 100 bucks with a lifetime warranty & due the labor yourself if your mechanic smart, its pretty simple.. dont let someone rip you off !
my codes where something like p0 something.. dont remeber
but they were cylinder misfires...
my car is an inline 6 so im not sure how the coilpacks work for the V8 you have...
but yeah just giving you my insight, good luck bro !
i know its frustrating -___-
Old 11-16-11, 06:11 AM
KingNasGS4
KingNasGS4's Avatar
I wish the fix was the same for every situation but its not. I turned out to be the lucky one....
shows proof that everything on here can't be taken as gospel (no offense to anyone on here)
but every car is different . the symptoms may be the same but the problem and solution could be 2 different ends of the spectrum.
I just hope this thread gives members other ideas as to what their problem could be...
I thought my coils were gone, I had severe misfiring, or something worse.
I hope you guys solve your issues
Old 11-17-12, 12:03 PM
jonnyful
jonnyful's Avatar
had the same problem....found out that there was oil in my spark plugs<<< .(reason for a mis-fire) Had a bad gasket. whats crazy, is that i had thought that it was the cat converters, because that was the code that was showing an error. but the short story is that instead of paying over a thousand dollars to fix the cat converters, i only spent 400.00 to fix that bad gasket and new spark plugs. car runs like new. I can feel the power in it now. that made my Friday!!!!!
Old 02-03-14, 07:08 AM
driver1988
driver1988's Avatar
my car stated doing that today. good trouble shooting guys
TKnight96
ES - 5th Gen (2007-2012)
12-01-18 12:39 PM
Cut-Throat
10-11-17 05:46 PM
P Rock
01-13-16 09:54 AM
NYKnick101
08-04-14 12:25 PM
twentyone
Performance
04-18-07 07:43 AM
Quick Reply: VERY Major issues... CEL Blinking
