Can OEM HID headlights work on NONE HID car?
Old 11-01-11, 09:18 AM
Nosexnolex
Nosexnolex's Avatar
Default Can OEM HID headlights work on NONE HID car?
I wanted the stock OEM HID lights with self leveling etc. Would that work on my NONE HID GS?
Old 11-01-11, 09:20 AM
GSteg
GSteg's Avatar
You can easily put OEM HID into your car, but integrating the auto-leveling will be tricky. The self-leveling feature hardly makes a difference.
porn-adkt
porn-adkt's Avatar
if the complete system is swapped .YES
Old 11-01-11, 09:45 AM
Nosexnolex
Nosexnolex's Avatar
When you say complete, is there anything else involved besides headlights? Thank you.
Old 11-01-11, 10:01 AM
IXI187IXI
IXI187IXI's Avatar
projector! there is nothing worse then being in front of someone with an improper hid setup with light scattered all over the road.
Old 11-01-11, 10:07 AM
SaiyanGS3
SaiyanGS3's Avatar
Please re-read his original statement buddy.
Old 11-01-11, 10:47 AM
Neo
The One
Neo's Avatar
There are also sensors at the front and rear of the car.
Old 11-01-11, 11:24 AM
SPRTNYDSN
SPRTNYDSN's Avatar
found a similar thread...
https://www.clublexus.com/forums/gs-...002-gs300.html
Old 07-26-12, 02:38 PM
YxUxMADDDD
YxUxMADDDD's Avatar
Any status on this?..
Old 07-26-12, 02:42 PM
abounly
abounly's Avatar
You need sensors front and rear for autolevel as they mention on the other thread.
Old 07-26-12, 03:22 PM
nytefire
nytefire's Avatar
Don't forget if they wanted the levelers, the dash harness and headlight harness are different on non HID cars. It takes bit of work to get these working properly without those 2 harnesses.
Old 07-27-12, 08:25 AM
YxUxMADDDD
YxUxMADDDD's Avatar
Yes it will work but if you're trying to use the auto leveler, good luck to you. It would require front and rear sensors that non hid don't have. The only thin you would need is a 9006 aftermarket hid wire harness that connects the non hid plug to the aftermarket oem hid ballast. Search and you will find what you're looking for. There's a guy that I commented on earlier in regards to the same exact subject. PM lexusondubs cause he did this years ago and it tells you exactly what to do. Or pm pinoy8317. It's a great switch but don't waste your time with the auto leveler cause its a MAJOR hassle. Just manually adjust your beam and call it a day!!
Old 07-27-12, 10:49 AM
str8lucky
str8lucky's Avatar
You can get pigtails to rewire from stock 9006 to the HID, but the auto-leveling is a huge project. I would just swith to the HID and call it a day.
Old 07-27-12, 06:45 PM
YxUxMADDDD
YxUxMADDDD's Avatar
https://www.clublexus.com/forums/gs-...on-hid-gs.html
YxUxMADDDD
04-01-19 09:04 AM
ErickGS300
08-15-12 02:22 PM
Caoboy
01-07-10 06:17 PM
illtech
07-12-08 07:17 PM
Tchan1
Lighting
03-14-07 11:21 AM
Quick Reply: Can OEM HID headlights work on NONE HID car?
