I decided to wetsand my headlights
#31
Puff... I think you should of traded in the wife instead of the evo.. just kidding.
I will get new headlights... But I couldn't stand looking at these anymore. My evo should get tuned by next weekend... 600 on e85 or I'm lighting a match and throwing it in the car. Lol
#32
Clear... I have 0 patience. That's why I used one grit paper and skipped the compound. I'm an anxious s.o.b.
Puff the evo looked great. I need a jdm rear and is be set.
#35
i did the same thing with my ligthts except i just went right to 2000 and used a compound and polish to buff it out and it worked fine, but i also tend to do things the lazy way. it may come out better if i started with a lower grit. i would recomend not going below 600. 100 grit would murder your headlights. make sure to mention to hand sand. might also want to reccomend not using an electric sander youll also mess up the headlight
#37
I just did this on my moms ls430 and I need to do this to my GS300. I only went down to 800 and back up to 2k. I wouldn't ever go past 400 grit!
Looks good. Whats up with the mix matched rims on the GS? Front driver is diff than others.
#44
I would love to get a set of supra tt wheels on them to match the motor setup
