Rear lights not working..just installed led's
I just installed a pair of 7443 leds that I purchased from vleds. As soon as I installed them and started the car I had the light on the dash go on for a bad bulb. Not tragic I figured and thought I might need to add a resistor to fix the issue considering the lights were working fine. Fast forward to later in the day at first my rear lights were working fine , but after leaving a store I noticed none of my rear lights including my license plate lights are now working. So my question is..do I need to run a resistor with these bulbs? or can I not run these bulbs at all? Im gonna start tomorrow morning with checking the fuses and then if need be ill take out the led bulbs. Thanks, and Any help is appreciated
these are the bulbs also
http://www.v-leds.com/Exterior-LED-B...96920-1-2.html
They were both working at first. I know if you put them in and they dont work to flip them for polarity, but that wasnt the case. I just got back from the garage and yes the fuse was blown, but there is worse news...what could cause the bulb to melt and break like this?
4urxtc
SC- 1st Gen (1992-2000)
33
04-24-11 05:32 PM
racinghart
01-08-07 09:43 PM
