pics of my 2001 GS430, finally!!!
u sure that One that I saw that like, I think it SRT or something kept having a ecu wiring diagram with it, u had to change? Let me see if I can find it....
To be effective, a directional tire is only meant to spin in one direction. The tread is designed to channel water off of the tire in wet conditions. The tread makes an "arrow" if you will, that should be pointing towards the front of the car.
Your rear driver side tire is going the wrong direction. Check your other tires to ensure that they're pointing in the correct direction.
Also if you can hold off on new wheels, use up those tires first as they're a fantastic design with a reflecting price. (I have the same ones )
