Question about Spacers
Old 11-15-11, 09:40 AM
AtlantaVIP
AtlantaVIP's Avatar
Default Question about Spacers
I have some 1/4" inch spacers(I think 10mm) that I would like to put on to make my car a little more flush. Question is, Can I safely run these spacers on stock studs? Also the spacers are type that just slides on to the studs and no extended studs. Thanks for the help Fam!
Old 11-15-11, 09:42 AM
lunatyk
lunatyk's Avatar
No............
Old 11-15-11, 09:50 AM
AtlantaVIP
AtlantaVIP's Avatar
actually I think they are 6.35mm spacers
Old 11-15-11, 09:51 AM
LuxuryGS3
LuxuryGS3's Avatar
I've always been told that if you're going to run spacers make sure they have extended studs..
Old 11-15-11, 09:52 AM
AtlantaVIP
AtlantaVIP's Avatar
Originally Posted by lunatyk
No............
Really?? I need more input on these please people. I just wanna make sure its safe to do this. I got my fender pulled and lost my flush swag
Old 11-15-11, 10:15 AM
abounly
abounly's Avatar
Anything over 5mm on stuck stud is dangerous. Even on 5mm it still dangerous. I think you need like 7 full turns to be okay.
Old 11-15-11, 10:23 AM
chObert
chObert's Avatar
yea i always wanted to know if you could put spacers on stockies...
what size are the extended studs... or do they come in 1 size?
Old 11-15-11, 10:38 AM
5t341th
5t341th's Avatar
max i would do is 5mm. stock studs are short. go buy longer ones. its cheap
Old 11-15-11, 10:39 AM
MrExecutiv
MrExecutiv's Avatar
You'll have to use extended studs for safety. You won't have enough threads to lock the lug nuts.
Old 11-15-11, 11:05 AM
AtlantaVIP
AtlantaVIP's Avatar
Thanks fellas. How much are the longer studs? no spacers just longer studs
Old 11-15-11, 11:06 AM
AtlantaVIP
AtlantaVIP's Avatar
Also where can I buy the longer studs?
Old 11-15-11, 11:43 AM
Infamous 1
Infamous 1's Avatar
ARP makes good studs. Also, many of these spacer companies carries extended studs.
4play4dr
Suspension and Brakes
21
07-07-15 03:20 PM
Jzsicklexi
07-20-12 06:05 PM
stevenjai
03-29-12 07:21 PM
Wierdazndu
10-15-09 11:20 AM
wongerZ
01-28-09 06:30 PM
Quick Reply: Question about Spacers
