want to lower my car
I am currently thinking about lower my 99 gs300. The only thing I am skeptical about is that my father is a mechanic and has been for many years says that lowering a car is no good for the other suspension parts, such as ball joints and bushings. Has anyone on here who DD their car lowered have any problems with any other suspension parts? Also my car only has 50,000 miles on it and i want it to last
Well unfortunately our cars suspension have problems usually once you get closer to 100k as far as ball joints and bushings. There are plenty of threads on here discussing the various problems. I am at 180k miles and working to get my new car ride back replacing various bushings. As far as lowering you have options. I just ordered some tanabe nf210's which have a mild drop but keeps the oem ride and I am adding some small rca's to clear my LS400 big brakes. Yes you cause added wear and tear but its a matter of how much you lower it. Slammed yes the suspension is being strained alot. Me , I will have a 1.5-2" drop and I don't think I have much to worry about. You could also go with rca's which are spacers that retain the suspension geometry while lowering the car I believe. All the information is on here you just have to find it. Good luck
I've read about the different ways people lower their cars here and the positive and negatives of each. I'm asking which is best or which gives the drop I want because currently I'm not sure how low I want to do. What I'm trying to ask is that if I do decide to lower my car will my car need more maintenance in regards to other suspension parts? And what kind of maintenance are we talking about if any.
That being said I personally know of two GS' that have been lowered for over 120,000 miles with only lowering springs with minimal issues up until recently when I forced them to replace their ball joints and control arms out of safety.
Ok so how would I go about correcting the non adjustable parts? And depending on how low I decide to go I'm guessing more correction will necessary and might not even be possible right?
welcome buddy. this topic is pretty much talked about all the time. if u want a nice simple drop id say a nice set of drop springs should ease off the stress on your suspension. anything lower, youll need to spend to beef em up..check FIGS Engineering if youre looking for aftermarket parts.
So it seems that the lower I decide to go the more work it will be. If i do decide to drop my car I would most likely go with coils because of the adjustability. Thanks for the help
if your going coils i would recommend the stance GR+ they ride really good, close to stock imo and pretty budget oriented. you can hit up nick from THmortorsports here in the forum, great guy to work with and will cut you a pretty good deal. and like everyone says lowering you car will cause stress to other suspension parts, like balljoints but a set or RCA can help with that and figs also have other suspension goodies to help. GL on your decision
