Is it Typical for these cars to have uneven camber on the rear?
Old 11-16-11, 02:39 PM
MDSC
MDSC's Avatar
Default Is it Typical for these cars to have uneven camber on the rear?
I just finished replacing the Rear Knuckle Carrier bushings which had decent amount of play in them and was hoping that it was going to correct my Left Rear Camber issue. I havent had the car on the machine in a while but i can visually tell that the r/rear has about 1-1.5 degrees more of negative camber. The Camber bolts are maxed out to positive setting on both sides and its still uneven. I have done many close inspections of underside of the rear suspension and i do not see anything bent. The lower rear control arm looks to be very straight. I also have been paying attention to other gs on the road and noticed that most from what i can see stock cars have more negative camber on the left rear also. I have a friends 00 GS400 in my shop now(stock car) and he had a 4 wheel alignment done last year and i can see that the left rear camber bolt is adjusted all the way to positive setting and right rear is beraly turned to positive side. My car is lowered on Tein CS. I know i can leave the left rear where it is and match the right rear to the left but i would like to know that this is normal before i do this, or do i have a problem
Old 11-16-11, 02:41 PM
J$mooth23
J$mooth23's Avatar
Typical, based off the 2 GS's that I've had.
Old 11-16-11, 02:52 PM
GS4_Fiend
GS4_Fiend's Avatar
Typically. Reason why is when you lower the car, the right side is gonna be lower than the left
Old 11-16-11, 02:58 PM
MDSC
MDSC's Avatar
I dont think that height is the reason though, i see this on stock cars as well. Also remember my car is lowered on coils and is very even. Also its the left side(driver side) if the right was lower it would have more negative camber.
Old 11-16-11, 03:13 PM
GS4_Fiend
GS4_Fiend's Avatar
I dont know about urs but my right rear has more negative camber because it needs to be lower than the left to be even height if you know what im talking about
Old 11-17-11, 05:33 AM
MDSC
MDSC's Avatar
anyone else have input?
Old 11-17-11, 03:50 PM
Brian@Vossen
Former Sponsor
Brian@Vossen's Avatar
We have know about this for about ten years
Old 11-17-11, 04:56 PM
1sWt2GS
1sWt2GS's Avatar
same with mine bugs the heck outta me
although its not a whole 1 off but then again it depends on how low your lowered.
Old 11-18-11, 10:02 AM
MDSC
MDSC's Avatar
so is there a solution to this or should i just match the right rear to left rear?
Old 11-18-11, 10:24 AM
Bnastyy
Bnastyy's Avatar
I also have camber wear on my rear left..more then the others
Old 11-18-11, 12:20 PM
MDSC
MDSC's Avatar
Originally Posted by Ar15to
I have the same problem on my lowered 2000 GS4. I was told I need to change the rear knuckle bushings, and rear toe arms. I will update when I get these parts changed. Same issue I got like 3 aligments done in like 3 months and everytime it was out of wack and destroying my tires.
i also thought this, toe arms arent going to fix your camber i just changed the spindle carrier bushings and it looks like it got a little better.
Old 11-18-11, 03:26 PM
BigGene
BigGene's Avatar
I haven't had any issues with the rears as far as camber is concerned, but I do have some issues with the toe being slightly out.
Bocatrip
02-17-22 02:02 AM
Letsstance
Suspension and Brakes
03-28-15 12:37 AM
EffSport
23
02-13-15 08:41 PM
menty
09-06-09 06:19 PM
Quick Reply: Is it Typical for these cars to have uneven camber on the rear?
