Concerned about amount of heat from led tail resistors
#82
Peltiers require quite some power to operate. You will also need a big heatsink and a fan to cool the hot side. The better you cool the hot side, the colder the cold side will be. It looks like overkill for this kind of application though. I had peltier cooling on my PIII back in the day ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Just epoxy some large heatsinks on them. Passive cooling is the best solution here as it won't require any maintenance afterwards.
#84
Hey idk if you found a place to put em yet but I found these installation instructions. I guess you can just follow the pictures. http://www.valuepicturehosting.com/a...J1_install.pdf It looks like they put the resistors behind the lights. Btw Nice tails
#86
Guys, save yourselves the time and money, don't install the tail light resistors and just do the indicator light mod here: https://www.clublexus.com/forums/lig...l?ref=esp-link
Just installed some depos on a 98, did this mod, works great. Easy to reverse if needed and you don't have to open up your dash.
#88
I'm just going without the resistors with the indicator light on. Doesnt really bother me, I just check every now and then to see if I really have a bulb out. So far these are working great for me.
#89
So does anyone have an idea of where to place those resistors without it having any impact on possible safety hazard issues? I can't recall which thread I read awhile back where they shrewdly tucked the resistors. I'm about to buy some but don't wanna deal w/ any dash light indicators. Thanks guys ~
