Concerned about amount of heat from led tail resistors
#106
Thanks for the info Jeff! I just changed out my reverse lights yesterday and noticed the resistors on the inners have hot spots (starting to bubble from heat). I mean they work fine and no indicator light but it definitely raises a concern. But It looks like I'll be taking them out.
#108
![](http://cargoodsya.com/0-photo/light/TAIL/ARISTO/type3/big5.jpg)
Here's a few photos how they turned out the RX. (And I'm still using the resistors LOL, but maybe not for long)
https://www.clublexus.com/forums/rx-...installed.html
#111
Here is a video of the Depos functioning. They look all good to me. I think the outer LEDs on the outermost taillights do not function as brake lights, at least that what it looks like http://youtu.be/dTNUop1_sfQ
#113
I'm getting the Braga Type-3's with smoked bottoms. These have large 3 row LED's. I just installed a similar set for the RX300 so I want them to match
#116
The fix is simple. Don't plug in the resistor packs. The tail lights will operate exactly the same whether you have the resistor hooked up or not. It's just an unnecessary power drain. One of the main benefits to upgrading to LED is to save power and reduce heat output. The resistor kind of throws all that out the window. The fix is as following: don't install resistor and then remove bulb indicator on the gauge cluster. If you can install the tail lights yourself, then pulling the bulb from the gauge cluster is a breeze. It will literally take you 5 minutes to do.
#117
Don't plug in the inner tail lights. The inner tail lights work independently of the outers.
lets see how long these bad boys last. im hoping they dont burn out before a year
#118
I have the braga type 3 and I get the dash indicator when I press the brake, and leads or info on installing after market resistors? I don't wanna shorten the life of leds by not using resistors, thanks!
#120
The resistors do not lengthen the life of the LEDS. AFAIK, they are ONLY there to prevent the dash indicator from illuminating. I just cut the wire to the rear light module int he trunk. There is a thread here on that.
