Instrument cluster/radio/windows/side mirrors not working after theft attempt
Hi, my car was broken into a couple of nights ago, and they attempted to steal my alpine double din. They broke the climate control in half so I purchased a new one. When I start the car nothing powers up.
The instrument cluster is completely black, the new climate control doesn't work, neither does the radio. The windows, turn signals, wipers, side mirrors and sun roof all do not work either. The HID's however do power on.
I have searched the forums for this problem and I did disconnect the battery in attempt to reset the computer, but still no luck. I checked every single fuse and had to replace the radio fuse. I also took out the cluster to make sure it was still plugged in. Could there be an issue with a ground wire somewhere? Any input or suggestions would be greatly appreciated. Thank you
Yup, checked every single one. Only bad one was the radio fuse, and I replaced it.
Yeah, I checked the fuses under the hood as well, they were all fine. All the wires inside the car are still intact as well. Maybe a relay issue somewhere?
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Looks like I might have to just bite the bullet and take it to the dealership, holding my breath..
